VAF Forums
-   RV-4 (https://vansairforce.net/community/forumdisplay.php?f=9)
-   -   Dynon Autopilot (https://vansairforce.net/community/showthread.php?t=79582)
redhawk 12-02-2011 11:32 AM
Dynon Autopilot
Looking for someone that has installed a Dynon autopilot in a RV4 that had to make up the roll servo bracket.
They make a kit for the pitch but not the roll.
Any advice is appreciated!
hcccs 12-03-2011 02:10 AM
Dynon autopilot
I haven't yet installed my autopilot but I have made the bracket. I intend to make an installation like the RV-6 so I have had to enlarge the hole in the fuselage rib where the aileron pushrod goes through to make room for the servo pushrod. The installation will be nearly identical to the one for RV-6.
Skysailor 12-03-2011 07:46 AM
You can use the Dynon RV6 roll servo bracket with no problems.
rv4ross 12-03-2011 08:42 AM
RV4 Roll Server
Redhawk,
As Skysailor and Hans say above, I to am using the Dynon Rv-6 roll server mount and I'm kind of following Tru Trak's method of installing the servo onto the fuselage belly skin with a hard link to the torque tube with a welded tab. Just didn't want to mess with trying to install it in the wings after they are completed.
Take a look at this link for some guidence.
http://www.trutrakflightsystems.com/...ollInstall.pdf
Ross Scroggs
RV4-3911
Locust Grove, GA.
