VAF Forums
-   Alternative Engines (https://vansairforce.net/community/forumdisplay.php?f=22)
-   -   Egg Subie Flies at Van's (https://vansairforce.net/community/showthread.php?t=7796)
rv6ejguy 05-16-2006 10:44 PM
Eggenfellner's Yahoo group had some details on a flyoff between a factory O-320 C/S 9 and an Eggenfellener Sube powered 9. Very interesting. Hopefully Van's will do an article in the RVator soon.
Deuskid 05-17-2006 05:34 AM
Ross -
thanks for the 'heads up'.
John
Jconard 05-17-2006 06:45 AM
results???
If you know them, please share, not sure what to make of your comment that they will be "very interesting"
Scott DellAngelo 05-17-2006 06:59 AM
129RV the factory 9A with Hartzell 2-blade CP prop against a supercharged Eggenfelter Subaru with 3-blade MT prop. Factory plane is 160hp not sure what they say the supercharged Subaru is.
Cliff note version is the factory plane weighed 105 lbs less and outclimbed and outran the Subaru. The Subaru burned total less fuel over a flight, which the factory plane burned less in cruise but more in climb.
To me that all sounds about right, nothing suprising.
Scott
#90598 - N598SD Flying - 31.5 hrs
rv8ch 05-17-2006 07:44 AM
Subaru vs. Lycoming "fly-off"
Here's the full text so you don't have to subscribe to the E-SubieForum group to read the story:
I took my plane to Van's last week for a head-to-head comparison
with their RV-9a. Dick Reeves joined me for moral support. Van's
plane, N129RV, sports a Lycoming O-320-D1A and a 2-blade Hartzell
CS prop. Mine, N29GJ, an Eggenfellner Subaru 4-cylinder with
supercharger and 3-blade MT CS prop. I weighed in at a calculated
empty weight of 1183 lbs, which is 105 lbs heavier than Van's. Two
AP servos, 9 lbs ballast, a little extra paint and maybe 5 lbs in
the panel would account for about 1/3 of that. I think the rest is
engine related ? 2nd battery, supercharger, muffler.
It was a beautiful blue day. In the 70's on the ground and 51 F at
8000 feet by afternoon. Ken Krueger was very thorough. Both he and
Ken Scott were happy to have an Eggenfellner visit Van's ? in fact
several on the staff came out to welcome me. Both Ken Scott and Ken
Krueger took short flights in the right seat and I think were
favorably impressed.
The purpose of the first flight was to make some qualitative
observations about 29GJ. The plane was then fueled and weighed, as
was Van's plane. Pilots were also weighed and Ken took on 35 lbs of
ballast to make up for his light lunches and bicycling habit.
The 2nd flight was a full-throttle maximum climb to 8000 feet AGL
pressure altitude (we set ground elevation of 200 ft to zero on the
altimeter). Timed from roll to 8000 ft was 6 min 9 sec for Ken, and
6 min 40 sec for George. A 2nd climb test later took 6:10 and
6:54. So climb advantage went to Van's and the 105 lb difference
would, I think, accounts for much of the difference. My IAS isn't
calibrated well and Ken tried to match my ground speed to yield a
fair comparison. These climbs at 2700 rpm resulted in temperatures
as high as 236 F. I always take off at 2500 rpm and usually reduce
to 2300 after 1000 feet, so don't usually see temps above 200 F.
Cruise temps are often right at 188 F, both oil and coolant.
The next part of this flight was a 5 minute speed test ? full bore
at 8000 density altitude. Ken gained about ? mile on me and
registered 6 mph faster on the GPS (a one-time look). The Subaru
consumed about 6% less fuel for this flight.
After returning for refueling and something to eat, we were back in
the air for the 3rd and last flight. We did a 2nd climb test and
then a cruise to Eugene and back ? a side-by-side flight of about
170 miles round trip at 8000 density altitude. I chose the speed
and went with 2300 rpm WOT on the outbound and 2000 rpm WOT for the
return. We switched tanks to separate cruise efficiency from the
climb and descent. The Subie used 2.5 % less fuel for this flight.
Interestingly, the Subie used 8% less fuel than the Lyc for the
climb & descent portion, but about 2% more for the cruise portion.
Conclusions? To me, the planes seemed remarkably well matched in
performance. Horsepower from the 2.5 L engine/supercharger combo
pretty much matches the Lyc O-320 under 8000 feet and would yield
some advantage over a normally aspirated 160 hp Lyc above that
altitude. I'm happy with the results and proud of my airplane.
Van's 9-a is a light little hot rod that took me (if only slightly)
in both climb tests and full-out speed. If only I had removed those
tie-down rings??.. And having to refill with 100 LL at $4.00/gal
reminded me of another reason I like my Eggaru. It was a good day!
Joey 05-17-2006 12:57 PM
Van's plane, N129RV, sports a Lycoming O-320-D1A and a 2-blade Hartzell CS prop.
That's interesting, N129RV had an O-320-D3G with an MT three-blade prop at the time of the Cafe Foundation report. I wonder when it changed and how the performance was affected?
And having to refill with 100 LL at $4.00/gal reminded me of another reason I like my Eggaru.
As a side note, 91 octane autofuel is acceptable for use in the O-320-D1A.
N941WR 05-17-2006 04:16 PM
One of the blades was damaged and the overhaul cost of that one blade (includes overhauling all three blades and rebuilding the hub, etc.) was about the same as the cost of the new Hartzell CS prop.
That is the Reader's Digest version, the entire storey was in the RVatior.
