VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   P-Mag 10:1 comp pistons timing (https://vansairforce.net/community/showthread.php?t=77947)
Ant CB 10-18-2011 08:38 PM
My Slicks are due for the 500hour inspection and I'm thinking of getting a P-mag.
I've got 10:1 CR pistons and fixed pictch prop so I retarded the timing to 20 degrees BTDC to give a little more detonation protection.
Can the P-mag be set to fire that late? From what I understand, the latest it will ever fire is 25 degrees BTDC.
N941WR 10-18-2011 08:49 PM
Welcome to the VAF!
Yes, the P-mags can be programmed to do what you want.
You can plug each ignition into your computer, one at a time, using the EICAD program available on the Emag site, and set the ?B? curve to anything you want.
Of course, using our EICommander makes setting up the P-mags a lot easier.
Ant CB 10-18-2011 11:22 PM
Does the mag have to be on the aircraft to do this? Can I do it on my kitchen bench?
N941WR 10-19-2011 03:15 AM
No, it does not need to be on the plane. However, it will need power which can be provided by a 9 volt battery.
