How to fix chattering countersink hole?
G'day,
I am using a 3 flute #30 countersink tool for my fuel tank nutplates on my -7. Some of the holes come out ok. Some seem irregular as the bit chatters ( I believe this is the correct term...) Any ideas on the best method to tidy these irregular countersinks up, or should I just leave them be? Any advice appreciated. |
Might be too late but I heard the single flutes don't chatter as much
Make sure you have a new countersink bit.
Don't take too big of a bite on it. I think you are talking the small holes. Do them first put in the platenut and then countersink the big holes last. The platenut will hold the center of the countersink and it won't chatter on you. Hope it helps. Boomer |
The trick is to back up the flange with a piece of wood, clamp it tight and drill into the wood with a #30 then proceed to countersink, the wood provides a guide for the countersink pilot keeping it steady. It worked for me
Greg |
http://www.vansairforce.com/communit...ountersink+bit |
bit speed
If you want to fix the screwed up hole (providing you have enough material left) a) clamp a backup with pilot hole in it (any material will do) under the original hole b) turn your countersink very slow with light-moderate pressure hope this helps |
You can buy a single flute c/s bit, similar to what Rick showed but with a pilot tip like your 3-flute model.
It's been a long time since I did the wings; did you mean a #40 (3/32") c/s tool? FWIW, I followed advice of a few others on the nut plates that are riveted to thinner skins and dimpled both the skin's rivet holes and the nut plate rivet holes. It requires a female dimple die that's a bit smaller in diameter than a typical die, or filing down one side of a standard die. My experience was that the nested dimples seem to help keep the nut plate perfectly centered under the screw hole better than using a screw, and the screw isn't in the way when you rivet the nut plate. Charlie |
I did something similar to Greg with the exception that I got a piece of flat aluminum from Lowes and backed up my spar flange while I was match drilling. When it came time to countersink the guide on the countersink bit had something to guide it the last few mm. No chattering and perfect countersink.
2 flute
The 3 and 4 flute countersinks are really used for harder metals like steel. The single and 2 flutes are for softer metals. So start with that first off, also the pilot needs to be just a bit smaller than the hole you are c'sinking. Go slow and use a back up as described above. That works most of the time.
To fix the chatter marks use what Rick is describing, that works the best, just make sure you don't go to big with the size of the c'sink . |
I didn't like the 2-flute countersink, and found it had a tendency to *really* chatter. I *love* the 1-hole dude, but it is *aggressive* and I found it very easy to take too big of a "bite", especially at the ends of flanges and such (seemed like material would flex a touch more, and the hole with the cutting edge would "grab" it and dig in). Also, if you use a 1-holer, be sure to clear the chips after each countersink, or the swarf stuck in the countersink will make nice little circular scratches around the *next* countersink.
| All times are GMT -6. The time now is 02:31 PM. |
