RV-7A to RV-7?
Hi All,
I am new to the forum. My name is Kevern Brown, I fly 340-600 Airbuses for a major airline, part owner of a flight school and a maintenance engineer. I have a question, can a RV7A still in kit form, fuselage partly built be converted to an RV7 taildragger. The finishing kit still needs to be bought. All the best, Kevern |
Not a problem and Van's can email you the part switch out list... thay have it ready to go. :)
convert
yes i just purchased a rv-6a and ordered kit from Vans to make rv-6 be sure to order 1/14 flate stock about 40 inches to make horz rear mount its not included in kit
bob |
Can you convert a flying 6A or a 7A?
How difficult is it too convert a flying 6A or 7A to a tail dragger?
Welcome to VAF!!!!
Good to have you aboard. |
Thanks for all the info, I have just sold my 8 after the test flight, must have another to fly.
Built 6A, 7 and building a 6. Love flying both |
Not the case for me.
Missing: - F-711C HS attach bar stock - F-782D angle mount for new spar cover - Rudder control horn. - 90 deg AN fittings for brake lines where they penetrate firewall. - Al brake and fuel tube - fairings (the gear on the -7 was longer, but I was able to get my old leg fairings to work with a little modification) - misc hardware and rivets ( ihad most of this in my spare's) - Lot's of other stuff that you will likely want, but not necessarily need (i.e. new wing intersect fairings and rubber seal, -3 and -4 fiber lock nuts, heat shield foil for inside the cowl, electrical connectors if you cut wires, new lock washers for exhaust, proseal for sealing old gear cover plates over old gear holes if you want. Not needed: - lots of bolts - axle nuts - brake mount flange - Tailwheel parts - if you go with aftermarket fork and linkage Your best bet is to get the list of parts in the unique sub kits that Vans has (they will email to you) and sit down with the builders manual and plans to check all the parts. The F-711C bar can be tapered for the -7A, but you need to leave the material if your going to a -7 to support the tailwheel weldment. I think the quick build kits have untapered bars so they can be built up either way. Something to check... Greg |
Thanks, I have flown the One Design, the Pitts,Extra the 8,7,6 and the Super Decathlon amongst others, I just love flying tailwheel aircraft.
Thanks for the input, I am busy going through all the motions to ultimately come to a decision.
Regards, Kevern |
| All times are GMT -6. The time now is 03:32 PM. |
