VAF Forums
-   Alternative Engines (https://vansairforce.net/community/forumdisplay.php?f=22)
-   -   Moderators, where are the Honda threads? (https://vansairforce.net/community/showthread.php?t=771)
Tandem46 03-04-2005 10:33 PM
Moderators,
Under the alternative engine section there use to be a line of threads discussing the Honda aero engine. Now they're gone. If you use the search function then you'll find them. They seem to be hiding somewhere.
Tobin
DeltaRomeo 03-05-2005 05:43 AM
Hey Tobin (and all),
Make sure you're in the Alternative Engines forum (http://www.vansairforce.com/communit...splay.php?f=22) and look at the bottom of the screen. You'll see a 'Display Options' section. You probably have the 'From' drop down box set to a value shorter than the length that thread is up. Set it to 'Beginning' and I bet it'll show up.
PS: You can set your 'UserCP'/'Edit Options' value to reflect this over all forums.
B,
Tandem46 03-05-2005 07:04 PM
Thanks Doug, that did the trick. Now I feel like a putz.
Tobin :)
Jaypratt 03-07-2005 06:36 AM
Tobin
I had to ask the same Question,
Doug figured it out while I had him on the phone
