VAF Forums
-   RV-4 (https://vansairforce.net/community/forumdisplay.php?f=9)
-   -   Question for RV-4 builders (https://vansairforce.net/community/showthread.php?t=77080)
rv4ross 09-26-2011 01:23 PM
I have my fuselage out of the jig and leveled. Verticle stabilizer and rudder installed and now need to figure out a way to set the rudder deflection to 35 degrees per the manual. I've seen Van's method in the manual, it seems doable but there has to be an easier way. Does anyone have a better method of measuring this or a better idea?
Ross Scroggs
RV4 Fuselage
Locust Grove, GA
#3911
fixnflyguy 09-27-2011 12:12 PM
Rudder deflection "tool"
I made a very simple cardboard template using the shape of the vertical rib and rudder rib (viewing down.I used the bottom rib of the vert fin ) layed over a centerline, then marked a line from hinge centerpoint to a 35 degree mark on my trusty elementary school protractor....cut out with scissors to the rib template ,and set my rudder stops to allow it to swing same in either direction. Just hold it on each side of vertical depending on which stop is being adjusted. I did exactly the same on elevator. Dont need to be too technical here, its just a simple measurement.
Good luck !
pierre smith 09-27-2011 12:30 PM
It's easy.
Ross, deflect the rudder by hand and shoot for 1 1/4" distance from the elevator and you'll be close enough.
Best,
rv4ross 09-28-2011 06:01 AM
Question for RV4 Builders
Pierre and Bill, Thanks for the reply's. I like the "That's about right" approach so my give that a try and see how close it comes out. I did get a suggestion from a friend that is not on the list saying to use a compass and determine what heading the rudder is when it is in trail and then just move it to the 35 degrees that I want. Sounds to simple but matching that against Pierre's suggestion should do the trick. Thanks to all.
Ross Scroggs
Locust Grove, GA
RV4 Fuselage
#3911
Clouddancer 02-19-2012 03:33 AM
Similar but different
That's how we did measure the deflecton of the elevators. We had to trim back the skins of the stabilizers a bit to reach the specified values without intereference of the elevator with the horizontal stabilizer skins. So we had to remove and attach the cardboard template several times. This way it was easy...
Cardboard template in place. The styrofoam rib goes in the horizontal stabilizer. Elevator's anles of deflection can be rad easily.
Cardboard template with styrofoam rib attached by doublesided adhesive tape
