VAF Forums
-   -   Fire Wall Blankets and Foam (https://vansairforce.net/community/showthread.php?t=760)
collinsj57@adelphia.net 03-03-2005 07:31 PM
If someone could help.
I see that many builders are installing a ?? black foam on the floor of their cockpit. I was wondering if someone could tell me what type of foam it is, How fire retardant it might be and who sells it. Second I have been looking for a good firewall blanket material , an suggestions ? I am concerned about flammability and most of the blankets I have seen clearly state they are not fire proof.???
Thanks for any help.
dav1111 03-03-2005 09:38 PM
Insulation Foam
This should answer all your questions:
http://www.wicksaircraft.com/catalog...925/index.html
Best regards,
Russ Daves
N710RV (RV-10 Reserved - QB fuselage stage)
N65RV (RV-6A Sold)
ClayR_9A 03-04-2005 09:19 AM
soundproofing
I bought mine here...
http://www.soundproofing.org/
Works great on the floor under carpet.
--Clay
Bob Axsom 04-03-2005 01:39 AM
Orndorff's Sales@fly-gbi.com
I bought mine from George and Becki Orndorff. They are located in Texas and their e-mail address is sales@fly-gbi.com. They sell everything for upholstering the the RV airplanes and they sell a video that shows precisely how to do it. The material for the floor and firewall are black and of similar size but I believe they are different (it's been a while so my memory may be faulty). Carpet goes over the floor pad and the foam pieces fitted into every subdivision of the firewall has an aluminum foil facing. All of the stiffener seams in my firewall foam mosaic are taped with aluminum foil tape. The floor is easy and the firewall is also but it is much more time consuming and it can be a little messy if you are not careful. Be sure that the firewall penetrations ground connections and everything else about is completely done because you don't want to go back in there after all that work to get a nice looking job done.
Bob Axsom
RV-6A, N710BJ
atreff 04-03-2005 10:19 AM
Get it from Hi Tech Foams, lowest price
I got my seat foam and all insulation materials from Jim and Janice Fix at Hi Tech foams: http://www.seatform.com, they were lower than the mail order houses. :p
robertahegy 04-03-2005 11:09 AM
Aircraft Spruce also sells it in many thicknesses.
Roberta
