1 Side Electrical / 1 side MAG - POH
Hello,
I am looking at an aircraft with single mag and single electroair ignition. I was wondering what others' start up sequence was like. I have the POH that comes with the plane, but would just like to compare with others. Can you post the "Starting Engine" portion of your checklist here? Thanks, Dan |
Just normal
Dan,
I have a RV-9A with one Slick (with impulse coupler) and one Lightspeed Plasma II. I don't do anything different than I would with 2 mags (or 2 EI's for that matter). Turn'em both on and crank. |
Ditto what David said with one couplered (sp?) Slick and 1 E-Mag.
On the -8A I fly
Electroair on one side, Bendix mag on other -- O320H2AD --
I start with the mag and then turn on the EI with a switch --- I have a key switch with the "P" leads attached and do a regular mag check --- my annoyance is when going from mag to both, then back to EI, I get a hesitation and backfire ---and then all smooths out -- still working on that technique. You can certainly tell when I switch on the Electroair --- engine gains several RPM and smooths out like crazy! |
Thanks guys
Thanks for the replies guys really appreciate it.
Alternate question
Does anyone know for sure if the impulse coupler is necessary with an E-Mag on the other side?
Thanks! |
Thanks Mel!
| All times are GMT -6. The time now is 04:13 AM. |
