VAF Forums
-   -   Where can I get this part? (https://vansairforce.net/community/showthread.php?t=73913)
tmillican 07-04-2011 01:59 PM
As a lesson learned the hard way, I have broken the nipple that connects my manifold pressure gauge to the aft side of the firewall. (see http://www.vansairforce.com/communit...ad.php?t=73153)
Can anyone help me identify the name or part number of the black plastic nipple that is broken in the following photos?
Troy
Mike S 07-04-2011 02:45 PM
FLAPS should have it
That stands for "Friendly Local Auto Parts Store"
Take the pieces to one, bet they will be able to match it up.
Good luck.
tmillican 07-04-2011 03:14 PM
Any idea what the mangled end looked like before I got through with it?
Is it a plastic version of the AN840-4D nipple? (http://www.wicksaircraft.com/catalog...2d6bd9f3acef6f)
PaulR 07-04-2011 05:22 PM
Hose Barb
I'm guessing that it's a hose barb for 1/8" rubber type tube for the manifold pressure line. The questions would be if that's the correct size and then what thread is on the other end. When I did mine, I used a 1/8 hose barb x 1/4-28 threads on the other end. I then faced the bulkhead fitting, drilled the proper hole and tapped it 1/4-28.
Hope that helps.
cwreeves 07-04-2011 06:20 PM
Barbed fitting
As I recall, it's a 1/8" pipe thread with a 1/8" barb fitting or maybe 1/16". Ace Hardware may carry it. Or you could try Home Depot. NAPA may also be a good source.
Charlie, RV-7 Tucson
Lars 07-04-2011 06:31 PM
Pretty sure that thread is 10-32, not pipe. Nipple is to fit 1/8" ID tubing. McMaster-Carr part number 5463K127 or similar should work.
N941WR 07-04-2011 06:49 PM
Check out this page on Aircraft Spruce's web site.
Also, can you convert to one of these fittings (in aluminum)? I'm using one and have had no problems with it.
Mark Browning 07-10-2011 12:15 PM
I have a spare you can have ....
Hello Troy
I have this part you need, i don't need it so you are welcome...
Just e-mail me your address and i will mail it out to you.
(It will take a few days to get to you though...as I live in UK )
Best regards
Mark
mbrowning@mazdaeur.com
lucaperazzolli 07-11-2011 02:11 AM
I'll give you
I have the part, if you like I can bring to you @ airventure (for free)
let me know
