Safety wire question
The four screws of the gascolator have to be secured with a safety wire. Is there a specific type (size, strength, material) of wire for this function or is any wire thin enough to go through the holes good enough? (It always bothers me when VANs treats me like I had built planes all my life and then makes me look like an idiot with my silly questions :D)
Jean-Pierre
In general, the largest diameter wire that will go through the holes is the usual.
Stainless steel safety wire that most aircraft supply places sell. I believe the gascolator screws would use .032 if it's similar to the ones on the -6's and -7's. Best, Pierre-John, |
Standard aircraft safety wire is stainless steel. Brass wire is also available but rarely used. The most common sizes are .020, .032 and .041. It is readily available from most aircraft supply houses in a 1 lb. spool, which will last you a lifetime.
In the application you describe, .020 or .032 will be sufficient. Any local A&P (mechanic, not the grocery store!) should be willing to give you a 3 ft. strand. If not, let me know and I'll mail you a piece. Info on how to safety is found here: http://www.faa.gov/regulations_polic...cumentid/99861 Ch.7, Sec. 7, pages 7-19 to 7-23. Hope this helps. |
These both have information regarding all of the standard practices used to repair and maintain aircraft. The assumption is that if you are building the airplane, you likely intend to repair and maintain it your self also. If this is the case, part of your "building an airplane" education needs to be getting familiar with the documents that your maint. and repair work is judged by. |
Thanks to all |
The FAA isn't all bad.
http://www.airweb.faa.gov/REGULATORY...E?OpenDocument Charlie Kuss |
When I was 13 year's old, I got the opportunity to start working on real airplanes, and was given a copy of AC43.13. Seeing as how lucky I was to get invovled in aviation at that age, I read the thing cover to cover, and have never been without a copy since. Of course, now I have it electronically on every computer I own....
Paul |
| All times are GMT -6. The time now is 01:51 PM. |
