VAF Forums
-   Northeast (https://vansairforce.net/community/forumdisplay.php?f=62)
-   -   Anybody have a good Icom A200 nearby? (https://vansairforce.net/community/showthread.php?t=73290)
tkatc 06-16-2011 08:30 AM
I have 2 A200s installed and ATC reports garbled transmissions. I would like to swap my radio with a known good radio to try and isolate the problem. This is a very easy swap....so is there anyone in the area willing to help?
sprucemoose 06-16-2011 09:44 AM
Can't help you directly, but I can offer an alternative. The A200 is a great little radio, but the factory settings for Mic Gain and Sidetone are set way too high for our high-noise cockpits. Try adjusting the gain down a bit on one of the radios and see if that doesn't help. Both are controlled via pots on the top of the radio that are covered by little silver tape pieces.
This is a well documented issue with this radio.
