VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Countersink cage too big for countersinks near flange (https://vansairforce.net/community/showthread.php?t=72789)
Fred's12#524 06-01-2011 07:57 PM
I am wondering what others have done regarding countersinking in close proximity to a flange. I have a 1 inch diameter countersink cage but it is too large to countersink some of the rivet holes in the Upper Caps. ATS has an 11/16s diameter cage but I am not convinced that it will work. Thanks.
FM
boom3 06-01-2011 08:06 PM
I don't have a picture to share, but I ground one side of the cage off. Just make sure you keep enough so that you can still hold it flat.
java 06-01-2011 08:09 PM
Freehand
If you're careful, do it freehand with the countersink bit without the cage.
J.Coles 06-01-2011 09:25 PM
You can buy the counter sinks that are designed to be used freehand. They save you time on the thinner parts where you will get chatter if you dont use a backup behind the part you are counter sinking. If you pracitice a few times you will get quite good at getting the depth correct.
Julian 120316
compren 06-02-2011 12:51 PM
I think...
I think you can also take your countersink bit and screw it into your speed deburring tool if so desired...I wouldn't want to countersink for a #8 screw using this method, but for countersinking for rivets in tight places it'll do fine.
rapid_ascent 06-02-2011 01:39 PM
Look on ebay you can find countersinks with are partial cages. That sounds like it should take care of your problem.
Auburntsts 06-02-2011 01:50 PM
I used my regular hole deburring tool (which is really just a pilot-less countersink bit) to handle a couple of countersinks that I couldn't use my microstop on--worked just fine.
clevtool 06-03-2011 03:19 PM
If you want to freehand, but need an extension you can pull the countersink apart pretty easy and use the shank. Keep track of how the parts go together.
rivetshaver 06-03-2011 03:52 PM
At my place of work, we call the pilot less cutters, "suicide countersinks", if not carefully used the name is appropriate.
Greg.
Fred's12#524 06-04-2011 05:38 PM
Thank you for all of your ideas and support.
Thank you to everyone for your ideas and support. I am now back onto finishing the V-stab and moving on to the rudder. This is a great family to belong to.
FM
