The angle valve engine is also more prone to cylinder cracking. Ask any Mooney owner.
Mel...DAR |
You don't want an angle valve IO-360, because everybody you fly with will be jealous of your superb climb, cruise, and economy. Better steer clear of those things!
I flew behind angle valve IO-360-A series engines in two Mooneys and now my RV-7. I have nearly 2000 hours behind the angle valve engine and I love it. Cracking? Mooney drivers? Dunno about that. Don't know how those particular Mooney drivers OPERATED their engines. |
The angle valve does have more cracking (both case and cylinder[) problems than the parallel. But the angle valve is really worth it if you use the IO-390 since they don't make a parallel version of that :).
I'll be shopping for an angle valve if I can find one when I'm looking for an engine. Even with the 'problems'. |
Dem Dare Fighting words
http://www.lycoming.textron.com/main...Guide/360.html The IO360 is an awesome engine. Cylinder cracks, never heard of them specifically on this engine either, but if its a Mooney thing, its from high flying and trying to get down, shock cooling. I taught at flight club/school which had 30-40 planes, including a few Mooney's. The key in checking members out was to get them to understand they needed to think about letting down as much as 60-80 miles out to allow a (warm) powered let down. Flying well above 10,000 feet in a fast retract requires more descent planning than flying slower C172 at 8,000 feet. Of course the bone heads would go , Doha! I am too high, chop, drop and causing thermal stress, aka shock cooling. Yes Dan I am jellious. :D G |
First run cylinders aren't at much risk for cracking, no matter what you do to them. After about 3000 hours or so, the thermal cycles of startup and shutdown have accumulated to the point that the aluminum is weakened and more prone to cracking. For a real-world example, jump planes are the kings of the chop and drop descent, but their jugs usually make TBO. Respectfully, Dave |
I may be in the minority here, but I also think that the "advent of modern engine monitoring solutions" can only help to mitigate temperature-related issues of the past. That is, assuming the monkey with the stick in his hand knows how to interpret it!
If the engines operated at much lower speeds, smaller intake passages would probably have better filling characteristics than the larger passages and would probably have better power. |
Shock Cooling Myth or Reality or Note the Graph and narrative Of course there are no long term double crossover blinded prospective large sample studies to prove or disprove the case on either side I believe common sense and available data suggest that John is right. Keep it under 380degF to start with and you are unlikely to have a problem |
Makes me wonder how often people were flying around in the old days pushing red line on their CHTs, completely oblivious. It's a well documented fact that the fatigue properties of aluminum start to change at a faster rate in the low 400 deg. temperature range. IMHO, this is a much more likely root cause for cylinder cracking than the shock cooling myth. Instrumentation and the ability to know what it's telling you is gooooood. Yup yup yup. Dave |
| All times are GMT -6. The time now is 09:29 PM. |
