First thing I am going to do as a result of your experience is make sure the EIS fuel flow warning is set to a number just above the normal take off fuel. Also, the low pressure warning will be checked. These are items that will indicate a leak before the fire..... Excellent job flying the airplane. Very sorry the airplane is such a mess but what's really important is you walked away from it. It will be a while before you stop reliving this one. |
NOMEX
As a former race car driver I would have NEVER driven a single lap without wearing a NOMEX driver's suit, gloves, balaclava and FULL SET OF UNDERWEAR. When I read Doug's write up last week about his safety missive I had to ask myself why I wasn't doing the same thing in an aircraft? After all, the fuel lines on most aircraft travel through the cockpit.
I do believe adding a pair of NOMEX long johns, long sleeve top and gloves to our "Before Engine Start" checklist should be a serious consideration. It could literally save your skin... |
The best solution is??
Dan H- You've obviously researched insulation material options thoroughly. I have a 16yr old RV-4 that I didn't build. This particular incident and thread have made me seriously consider what is installed in my aircraft. I also suspect that better materials may have come to market since mine was built. What insulation did you choose for your RV?
![]() By steveingraham at 2010-04-05 |
ABC extinguisers BAD
It is worth considering the idea of building a whole new fuselage rather than repairing this one. At least discuss it with an expert before settling the insurance. If you need to replace the whole fuselage because of fire extinguisher powder, then that will be part of the settlement. For this reason, I made sure that the extinguisher in my hangar is BC-type. And the small one in the airplane is halon. Unfortunately it is hard to influence what the fireman who shows up at the scene uses. |
I did go online to research the MSDS for ABD powder, but could not find any reference to corrosive listing--------but that doesn't mean it aint there. My fire service tenure was over 8 years ago, so there is a chance the extinguishing agent has been changed-------but better safe than sorry. There are a lot of fire extinguishers sold that are make of aluminum-----for whatever that is worth in the discussion. |
My guess Mike - a rural fire department's dry chem extinguishers probably haven't been CHARGED for more than eight years! :p I doubt that the stuff has changed much, and I know that it makes a heck of a mess - I was told my an insurance guy in our department that if you use a standard size fire department one on an engine compartment, the car is likely totaled these days. Paul |
I believe the broke segments are right behind the firewall. The remaining Ozite insulation you see is attached to the firewall. The insulation on the floor are gone. The bottom with nutplates is actually on the bottom cowl that is forward and below the firewall. What you see below the brake line are part of the bottom cowl and left tailpipe. Bottom of the firewall is black band below the Ozite insulation. |
| All times are GMT -6. The time now is 01:18 AM. |
