VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   Dual mag EI solution (https://vansairforce.net/community/showthread.php?t=71690)
rjcthree 05-02-2011 10:35 AM
As I struggled through the D3000 P-lead termination (not the same as the std mag) I'm once again lamenting no real solution for electronic ignition for us dual-mag folks.
Right now the best bet to plug the hole with a single mag and a stand alone EI.
I want something smarter. I'm ~3 years away from the 5yr/500hr inspection on my D3000. That will run me ~$1200. Somebody come up with a $2000 solution for a dual EI.
Anybody listening?
Rick 90432
H2AD
N941WR 05-02-2011 12:38 PM
E-mag Ignition's new style P-mag should be ready and well tested about the time you need one.
They are looking the "H" engine as one of their customer bases.
RV8RIVETER 05-02-2011 02:21 PM
I am with you Rick. I have been eagerly waiting one since I saw the prototype pictured in the Oshkosh issue of EAA mag last year. I thought with the recent non support of the D3000's they would step up the progress.
IO-360A3B6D
Walt 05-02-2011 03:08 PM
How about the dual Lightspeed Engineering system with crank sensor?
http://www.lightspeedengineering.com...ualSystems.htm
RV8RIVETER 05-02-2011 06:54 PM
It is a good system and the designer Paul Lipps is first class, but dealing with Klaus is unpleasant and I want a compact solution that is simple plug and play. My personal preference.
