VAF Forums
-   -   Jacking RV's off the ground (https://vansairforce.net/community/showthread.php?t=716)
robertahegy 02-27-2005 01:05 PM
A while back someone asked about jacking the planes for wheel maintenance and for setting the plane and gear in a proper position to set the wheel pants. I've posted some pics on how I did it using two wing jacks from the Jackhouse and some concrete building blocks and chain.
Van's sells the plastic hard points for jacking the wings. They are screwed into the threaded holes for the wing tiedowns.
A chain is run around a pipe and secured to the tail tiedown or tail wheel. The pipe is anchored by running it through 4 concrete blocks. You can adjust for level by lengthening or shortening the chain and adjusting the wing jack height. A bolt and washers with a nut attaches the chain at the proper length.
The jacks aren't cheap ($165 each), so if you have a club or know other low wing plane owners, maybe you can share the expense. They really do a good job and safely get all wheels off the ground for a variety of reasons.
redbeardmark 02-27-2005 08:26 PM
jacking trikes
Thanks, Roberta. I've been wondering how to do that.
As an aside note, my new cowl inlet/FAB inlet plugs arrived in the mail. All three plugs attached together in an attractive package with N-number on it. Jenny at Kennon Aircraft Covers does nice work.
Mark Andrews N598X
Skyhook 02-28-2005 10:53 AM
I also got a set of jacks at the 'Jackhouse' and found them excellent. I had to cut the lock channels to fit, but those jacks are fine quality meant for the long term (insurance, cheap).
I also took some bolts of the samr thread as the tie-down rings, rounded the heads down to a conical shape to fit the cups in the tie downs and sunk a 300# 'deadman' weight into the hangar floor for the tail wheel connection.
This works extremely well and the set-up is a secure one; I've climbed in and out of the cockpit w/o any problems while the acft was jacked up.
Jim
robertahegy 02-28-2005 08:52 PM
Excellent idea on making the jacking hard points. Wish I had thought of that. Oh well, If I ever need a replacement, that will be it. I was going to sink an anchor in the floor, just can' decide where, yet.
I had a cover for my Cherokee from them (Kennon). Good people. I'll have to order the plugs for my 7A. Thanks for the referal.
Roberta
dan carley 03-01-2005 05:46 AM
jacks for rv's
van's just put one out recently. works great. on weighs 9 lbs with all the tools and tire patch kit, so you can put it in the plane just incase you get stuck. 200 bucks but well worth it. the plane can't slip off it.
rv8guy 03-01-2005 04:24 PM
can you tell me how to find the jackhouse?
Marshall Jacobson
robertahegy 03-01-2005 04:54 PM
They are at :
www.jackhouse.com
I have the model 12 for my RV-7A> it would probably be the correct one for your 8
Roberta
TerryPancake 03-02-2005 04:53 AM
Sweeeeeeeeet SLK.
Oh yea the jack are nice too.
:D
robertahegy 03-02-2005 04:56 PM
Thanks. I needed something that made me feel as good on the ground as my RV makes me feel in the air.
Roberta :) ;)
TerryPancake 03-03-2005 03:55 PM
Oh yea, your right the car is on the ground.
