VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   How tight for the alternator belt? (https://vansairforce.net/community/showthread.php?t=7125)
kevinh 04-17-2006 09:18 PM
Just curious - how tight should the alternator belt be? I've always heard press in on the belt with your thumb and it should deflect about 1/4". Sound about right?
mark manda 04-17-2006 10:53 PM
3/4" for me. Max.
David Johnson 04-17-2006 10:55 PM
Yup. Sounds about right to me, depending on the span between the pulleys. On the typical lycoming alternator setup, 1/4" would be about right. Tight enough not to slip under load and not so tight as to cause undue stress on the belt or bearings. If it's too loose, you'll note glazing of the belt surfaces in relatively short order. Most auto parts stores sell a belt tensioner that will provide a more exact reference, but I think the 1/4" rule is a good one.
vlittle 04-17-2006 11:24 PM
Torque the belt
Belt deflection is an unreliable method of tightening the belt.
Instead, use a torque wrench on the pulley belt and adjust the tension so that you get about 12 ft-lbs before the belt slips.
A loose belt can lead to under-voltage or over-voltage from the alternator. Overvoltage is caused by the regulator trying to force more output from the alternator while the belt is slipping. When the belt grabs, it puts a surge of voltage on the bus.
Please don't ask me how I found out!
ref Lycoming s. i. 1129A
Lycoming SI 1129A Accessory Drive Belt Tension
New 3/8? 11-13 ft/lbs 132-156 in/lbs used 3/8? 7-9 ft/lbs 84-108 in/lbs
New ?? 13-15 ft/lbs 156-180 in/lbs used ?? 9-11 ft/lbs 108-132in/lbs
Vern Little 9A
jarhead 04-18-2006 12:06 AM
Originally Posted by vlittle
...use a torque wrench on the pulley belt and adjust the tension so that you get about 12 ft-lbs before the belt slips.
I think you meant the alternator pulley nut, correct?
This is the procedure we were taught in A&P school, to comply with the Lyco S.I.
rv8ch 04-18-2006 02:13 AM
Alternator Belt Tension
Great info, Vern. I would have never found this in a million years. Thanks for posting it.
kevinh 04-18-2006 09:35 AM
Great info Vern. Thanks!
Davepar 04-18-2006 12:19 PM
That does sound like a much more accurate method, but I'm not sure I get it. You put the torque wrench on the pully nut, hold the starter ring in place, and then adjust the tension until the belt slips with 12 ft-lbs of torque??
jarhead 04-19-2006 12:42 AM
Yep, that's the extent of it. Obviously, you turn the pulley nut in the tightening direction so you don't risk breaking it's torque.
gmcjetpilot 04-19-2006 06:10 PM
Right-ee Tight-ee
What direction is that. I think the alternator (some not sure) is opposite of "right-ee tight-ee".
