got me a 396, now what do I need
It's here. yeah...happy birthday to me... a new 396.
What cable do I need to wire it into the ships power? I don't want to cut up the cords with the Garmin connector on it to get to the power lines. Is there a wire harness out there with a Garmin connector on one end and nothing on the other? It's going in an Air Gizmos dock. So I want to tie it into the ship power and audio panel (GMA-340). Thanks!! |
Pretty sure
Scott, check on the Garmin site, they should have a cable with that "round garmin" connector and the other end should just have wires hanging out of it.
I think this should do it... http://shop.garmin.com/accessory.jsp...0%2D10513%2D00 |
Also, don't be confused by the "audio" wiring that is integral to that harness. The audio you want to run into your GMA-340 is from the 1/8" stereo jack on the back of the 396. The audio wiring that's in the harness is for the automotive setup. Just an FYI...
I might be wrong - didn't sleep at holiday inn last night
Isn't the audio coming from the "garmin connector" the "warning audio" (TAWS like for obstruction, terrain, etc and the TIS warnings) and the audio coming from the "1/8 stereo jack" the XM radio audio? I don't have mine yet, so I might be wrong. |
Ah, ok
So, I'll assume that if you are in auto mode, then you get the "directions" in voice via those other pins? Also, when the "warnings" come thru on the 1/8 jack, are they mixed with the xm audio, or do they internally mute it? Not talking about with an audio panel, just the 1/8 jack audio? |
396 audio
Agreed
| All times are GMT -6. The time now is 09:10 PM. |
