VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   If you have Lightspeed ignition...... (https://vansairforce.net/community/showthread.php?t=69561)
gasman 03-09-2011 08:02 PM
How many hours are you getting form your auto plugs?
And what brand and # are you using?
Thank You.
Warren
Radomir 03-09-2011 08:33 PM
BR8EIX will love you long time (Iridium plugs)
Rick_A 03-09-2011 08:54 PM
I've had my current set of NGK plugs in for the last 130 hrs and the plugs are still in good condition. I just replaced my cylinders to comply with the ECI AD and will probably go ahead and install new plugs. I have a set of Iridium plugs on the shelf that I bought after I installed the NGK's.
As an aside: I changed my first set of plugs at 93 hours because the engine was not running quite normally and new plugs seemed to solve the problem. She started to run a bit rough again after about 45 hours on the second set and I replaced them with the set that I've been running for the last 130 hrs.
I'm pretty sure that my "plug problems" were really a connector problem. Even though I had done the "pull test" on the Faston connectors at the coil I discovered that one of the connectors came off way too easily when I was doing some maintenance the required me to remove the connectors on one of the coax leads.
drakerv 03-09-2011 11:55 PM
plugs
denso IK 27 from rockauto online. Amazing plugs.
Scott Hersha 03-10-2011 06:03 AM
I used the Lightspeed supplied W27-EMR plugs the first year, iridium IK-27's the second year, and now have a set of NGK's installed. I've noticed no difference in operation. Only difference for me was the price. I still have the iridium plugs, but will probably just buy NGK's each year and throw the old ones away - they're only about 2 bucks each. The advantage of the iridium is that the electrodes won't burn away as fast and should last 100K miles in a car..... not something we worry about in our airplanes.
LifeofReiley 03-10-2011 07:11 AM
NGK BR8IEX Iridium... cheap enough, change the on the condition inspection. I also carry a gapped set in the plane tool bag, just in case, as you're not going to find these plugs just anywhere.
Walt 03-10-2011 07:15 AM
Same here, hundreds of hours on them and still look good.
Ron Lee 03-10-2011 09:12 AM
Klaus does have a recommended replacement period for the wires. I had an issue where the connector at the plug on one wire was bad so I replaced the entire set. Kept some of the old wires for spares.
gasman 03-10-2011 10:10 AM
Walt, These plugs has a captive gasket........ how do you deal with them when you inspect the plug?
JoeBlank 03-10-2011 11:35 AM
Plugs: W27EMR-C
Replace or regap @ each condition inspection or 100 hrs.
Advice from Klaus to replace rather than inspect and regap. Plugs erode and resistance increases over time used. This makes the ignition coils work harder and will eventually fail them.
