VAF Forums
-   West (and Southwest) (https://vansairforce.net/community/forumdisplay.php?f=66)
-   -   Looking for Arizona advice. (https://vansairforce.net/community/showthread.php?t=69223)
rcarson 03-02-2011 10:17 AM
I hope to complete my 7A within the next year and order the engine and prop sometime this summer during Airventure since they always offer discounts. I will be installing the 0-320 160hp. My wife and I have decided to leave the great icebox midwest and move to Az. and looking at the elevations throughout the state makes it seem like a constant speed prop is a must. Any thoughts on the topic from the western folks? I like the simplicity of a fixed pitch metal prop but it only seems practical in the flat midwest.
rvator51 03-02-2011 10:39 AM
Fixed Pitch props - thumbs up
Fixed Pitch prop works great in AZ! May not outclimb a C/S but we go everywhere and never have had a problem. We do not consider it a safety issue. Lots of people here with fixed pitch props on their RVs.
Rosie totally concurs with Tom ;-)
Greg Arehart 03-02-2011 10:51 AM
I flew FP props out of the mountains in CO for years (in 172s etc.) and am flying FP RV-9 in Reno now. No issues at all, especially for RVs.
greg
Fred.Stucklen 03-02-2011 11:19 AM
Fixed Pitch Works
I flew into Leadville once in an RV-6A with a 160 hp o-320 fixed pitch prop setup. Take off at a 13,200' DA still had a 250 FPM climb rate with 3/4 tanks and me (235lbs) in the plane..... Yep, used a bit more runway, but it climbed just fine (had to lean for max RPM prior to take off...).
Fred Stucklen
RV-6A N925RV 2008 Hrs (Sold)
RV-6A N926RV 875 Hrs (Sold)
RV-7A N924RV 525 Hrs Flying
pazmanyflyer 03-02-2011 11:27 AM
I'm a newbie with the FP/CS debate but here's my opinion. I'm with Tom V. I'm sure a FP will do just fine and that is what I plan on until I have the $ for the CS. Remember that your not building a plane with C172 performance. The only time you'll really feel the climb performance suffer is in the extreme heat of the day which I don't think you'll like to fly in anyways. It's to uncomfortable. There are several FP RV's here in AZ.
RV7Guy 03-02-2011 11:36 AM
You'll be fine
As Tom noted, you'll be more than fine. Even the 160 hp is overpowered in the scheme of small aircraft. If money allows, go with the 180 hp. There will be no doubt then and the resale will be better.
Where in AZ are you looking? There is house in my airpark available in the Phx area. (P19)
rcarson 03-03-2011 07:20 AM
Arizona
Thanks everyone for the advice. Looks like I can stick to the original plan and use the fixed pitch prop. Love the simplicity and lower cost. I keep forgetting the 7 will still outperform the Cherokee I had by a considerable margin.
Sig600 03-03-2011 01:46 PM
FP or CS, the most important thing is that you go to Tucson and get a Sonoran Hotdog. Oh so good.
Radomir 03-03-2011 02:57 PM
You mentioned you're ordering an engine (as in "new") -- not sure it makes sense to stick an O-320 into an RV-7, since it costs virtually the same as O-360.. the difference in price is negligable...
rcarson 03-07-2011 08:57 AM
It's not price its experience with the engine and the fact that I can burn auto if I need to. It also is using less fuel and in the long haul with only a 4 mph penalty in top end it made sense.
