VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Luxeon LED Source (https://vansairforce.net/community/showthread.php?t=6866)
tx_jayhawk 04-07-2006 11:51 AM
Luxeon LED Source
All,
I have been googling to death recently, but I have not been able to find exactly what I need. I am looking for a source for encased, low-profile Luxeon LEDs. I'd like something that ideally could be mounted in a hole with only a DC power supply required (lense and LED together). I'd want it to have as wide of an angle viewing area as possible. I am thinking I have found a suitable source for the hockey-puck power supplies, but I still can't find exactly what I need lightwise. Most of the things I have found are LEDS only (not lense) and not conducive to mounting in a hole.
Any suggestions? The close thing I have found so far appears to be the Star/O.
Scott
7A Fuse
Brian130 04-07-2006 12:17 PM
http://www.candlepowerforums.com
those guys know where to find or can make anything you need.
RV_7A 04-07-2006 12:23 PM
LOL dude, you need to call me again...PM sent.
-Jeff
rv8ch 04-07-2006 01:37 PM
LED source
Probably not what you are looking for, but I've had good luck buying from these guys: http://www.besthongkong.com/
PH-SCP 02-06-2007 02:43 AM
I used two luxeon led's per wingtip, to build recog-lights. I had no problem to find and order these led's in our country. Be sure to use a proper heat-sink to prolong the led's life and light output.
This is how they came in the mail;
...and this is how they look in the wingtip;
the_other_dougreeves 02-06-2007 08:34 AM
I've been thinking of the exact same thing for our CT and eventually for our -7/9. That should be very visible and draw very little power. What is the angle on the lenses? 10 deg? Are they LuxI or III?
LED Supply is a pretty reliable group and have lots of drivers in stock, should you want to use one.
xavierm 02-06-2007 08:51 AM
eBay
I have bought from both LED Supply and Best Hong Kong. Both had fast shipping and I've had no problems with their products.
Don't forget to check eBay. I recently saw 30 Luexon III LED's that were a very reasonable price.
thallock 02-06-2007 12:02 PM
I have bought from LED Supply, Best Hong Kong, and Light of Victory on eBay. Compared to the two Hong Kong suppliers, LED Supply is way overpriced, so I would not recommend them anymore.
The first LEDs that I got from Best Hong Kong came fairly quickly, and measured closer to 18,000 mcd for 10,000 mcd LEDs, so that was a good purchase. I finally broke down and bought some luxeons from Best Hong Kong, and they took several weeks to arrive, but they did get here, and were as advertised.
I have made a couple of purchases from Lights of Victory, and the first was as advertised. The second was 130,000 mcd LEDs that measured closer to 65,000mcd, but I really was not that suprised, just disappointed. They are now showing 140 degree 20,000mcd LEDs, which might be just what you are looking for.
http://stores.ebay.com/Light-of-Victory-Led-Store-lvehk
http://www.ledsupply.com/
Tracy.
PH-SCP 02-06-2007 12:37 PM
Mine are Luxeon 1, with a 10 degree beam angle, they sell at ? 12,50 each in the Netherlands, that's about $ 16,00 your money....ordering 10-99 gives a 17% discount and ordering 100 or more, 30% discount. I just love their light output for the amount of current they draw, should work great for recog-lights.
the_other_dougreeves 02-06-2007 12:48 PM
I totally forgot to ask, but did you make the mounting piece yourself or was it provided?
