VAF Forums
-   Interiors (https://vansairforce.net/community/forumdisplay.php?f=89)
-   -   Classic Aero Interior Question (https://vansairforce.net/community/showthread.php?t=67558)
kbehrent 01-21-2011 10:43 PM
I've decided to go with the Classic Aero Aviator series seats and side panels. for my RV-9A slider. I would appreciate feedback/comments on the following:
1) Are headrests worth it? Does it really limit your ability to reach in the baggage compartment while seated?
2) Leather/Vinyl vs Ultra Leather? I would prefer Leather for the seats, but it appears if you choose to go Ultra Leather for the side panels to save weight, you have to use Ultra Leather for the seats or colors may not match up. Also, it appears from the picture they provide, the Ultra Leather wrinkles more than the Leather/Vinyl option.
Bavafa 01-21-2011 11:47 PM
I have them (leather) in my RV7A and love them, they are worth every penny. I had condisered the headrest but glad I did not get them. The added weight was my main reason for not getting them but after using them for the last two years, I was very happy for not getting them mostly for the restriction they create to the baggage area.
Hope this helps.
gordodavis 01-22-2011 06:06 AM
The headrest might get in the way, but they sure look good.
kentb 01-24-2011 10:49 AM
I have the headrest on mine.
My wife love them, but I don't like the way the seat belts route over them. It is hard to get them to route on either side and stay there.
It is also a little inconvenient when loading in and out of the baggage area.
Kent
TCONROY 01-24-2011 10:51 AM
Can't the back of seats easily be rotated forward to give more access to the baggage area? We are considering the headrest seats from CAD as well.
kentb 01-24-2011 11:18 AM
Hi Trevor...
The seat frame is solid and is hinged at the floor like the original seat. The whole thing rotates forward at the floor and is stopped by the panel. But without the headrest you would not need to move the seat forward, just load over it.
You can come out to Lenhardt's to look at my 9A if you want.
Kent
kbehrent 01-24-2011 11:34 AM
I appreciate the comments and I'm not surprised by the headrest comments.
Loading the baggage compartment is not a real factor for me since I installed a "tilt" option to my slider. However, I am much concern about being able to reach into the baggage compartment to get access to my OX bottle to turn on/off. I don't think that's doable now with the headrests.
On my other question, CAD is now offering the Ultra-Leather option instead of Leather. It's a real weight saver, but I'm concerned on the look and wear compared to leather. Also, CAD cautions that UL does wrinkle more on the side panels. Anybody go with the UL option and how do they look and wear?
kentb 01-24-2011 12:09 PM
O2 - Not a problem.
In my plane, I mounted the O2 behind the pax seat and against the fuse. side. I can easily reach behind the pax seat and adjust or inspect the top of the O2 tank.
Access to other areas are a little more restricted, being that my headrest is restricting me from reaching behind my seat.
Kent
kbehrent 01-24-2011 01:50 PM
Kent
I'm planning on placing my 02 in the same location. Good to know that you can reach it. Did you go with their side panels? If so, what material did you go with and do you like them?
Steve 01-25-2011 10:29 AM
After 364 hours in my 9A, I know that anything stashed in the back is pretty much out of reach during flight, especially when flying solo. I have the lo-buck Sportsman seats.
