Best RV friendly airport/FBO near Disney World??
Any one got any tips on the best RV friendly airport/FBO near Disney World??
My wife is running in the Disney half marathon end of Feb. and I do not want to drive!!!! |
KISM
I use KISM everytime I take people to Disney. Its by far the closest - and the friendliest for experimental airplanes.
KISM is friendly, but FWIW orlando executive is much closer to the Universal theme parks (just got back from there with the family).
We had a car service take us from KISM to the Hard Rock hotel (much nicer and a little cheaper than a cab). It took 20-30 minutes, and the guy said that Orlando Exec was much more convenient. |
Which FBO is the best for RV's at KISM?
Brantel,
Both airports are nice...Orlando Executive is closest. If you use "Showalter" at Orlando Executive, I promise your experience will be great. I've used them many times and I've never had a bad experience. My only complaint with Orlando Executive is a grumpy old ground controller. He needs to get a life, but the airport is just fine. David Watson |
I use Kissimmee Jet Center. I've alway had great service there no matter if I'm in the jet or in the RV. They've got the cheapest fuel too ;) Orlando Exec is a nice airport too - I second going to Showalter. They always provide great service. I'm not sure on drive time from KORL, but comming out of KISM, its a left turn on Bronson Memorial Hwy and a right turn on World Dr. into Disney. Takes me about 15 minutes. Be sure to keep an eye on the TFR over Disney while you're down there. Daniel |
my vote is for
ISM. a lot easier drive to disney. more choices for FBOs. Warbirds and museum on the field. I like it a lot.
check out this F-16 dead stick landing. http://www.patricksaviation.com/videos/SUPERGT/3384/ |
Disney airport
X04 in apoka is right around the corner from Disney. I have a hanger there that you are welcome to use. I can help you make arraingements for a car if you would like. If you would like more laid back(out in the country) I have a grass strip you could land at 45 minutes away from disney that has a small trailer(27') you could stay at. 52FA
Bill Rv 4 |
| All times are GMT -6. The time now is 10:23 PM. |
