Rudder Locks?
I want to make a simple rudder lock for those times when I have to park outside on a windy day, and just want to keep it simple and light. I have heard where folks just make a "U"-shaped rod that drops in a hole in the rudder stop and the horn - that sounds simple enough! Before I create one from descriptions alone, does anyone happen to have a picture they would like to share?
I already have a BIG "REMOVE BEFORE FLIGHT streamer from an F-16 to attach to it... :D Paul |
Center the tailwheel, lock the rudder? I thought only the nosewheel guys need rudder locks?
U Bolt, wing nut, red flag
Paul: I used a 1/4" u-bolt purchased from the aircraft isle at Lowes. The one I used looks like the ones show at this link: http://doityourself.com/shop/uboltsznupto4.htm
I also bought a 1/4 inch wing nut (you really only need the nut on one side), drilled a 1/4" hole in the rudder stop and just to the rear of where the rudder cable is connected to the rudder. Slip it in, wing nut on, done. Sorry, I don't have a picture. Total cost was about $2.00 plus the red flag. If you use this method, don't forget your preflight. And, put the rudder lock on the pilot side. Jack |
Maybe someone else will have a photo. |
Sorry no Photos
Mine are made from steel piano hinge wire (3/32" as I recall). I first made one for one side only but it was inadequate in a wind it actually worked its way out one time as compression and tension forces were applied. I made on for the other side as well and it no longer moves - period! I have them tied together with nylon wire bundle lacing tape (flat string) which hangs down below the fuselage with an obvious red flag tied in the bottom of the loop. I have one hole in each horn and each stop. I bent the wires at the proper locations to fit the holes when the rudder is centered.
Bob Axsom |
I used 1/4" steel rod bent into a [ shape with a hole drilled in one end. It slips into holes drilled in the rudder horn and stop and is held in place with a hairpin clip. I have a red remove before flight banner on it. Very small and light. If you heat the rod with a torch, you can bend nice tight corners and keep it small. I just use the seatbelt on the stick for the elevator and aileron lock.
Roberta |
Good Point Dan...
Thanks for the other replies - the piano wire "staple" was what I was remembering. Paul |
re: red flags and preflights.
One way to do it is either make a little holder (a clipboard with the right number of holes drilled into it to hold the red flags...clip your preflight checklist to it) or print on your checklist the number of red flags, locks, whatever you should have at the end of the preflight. Last step on the checklist is check all the holes, or count up the "remove before flight" thingies. Maybe I'm the only one that didn't figure this out on his own because it's so totally obvious, but I was clueless before I saw someone else doing it. |
| All times are GMT -6. The time now is 06:00 PM. |
