Please critique my panel.
This is my first crack at the panel layout for 313TD.
![]() This link opens it full-size. I'm missing the aux power and audio input, but this is the current layout. Apologies for the half-***** throttle quadrant drawing, that's just in there to give me a rough guide for obstruction of switches by the real thing. To do the layout, I used a CAD program called DraftSight, which is free, and uses dwg files as its native format, so I was easily able to copy and paste switches from the Aeroelectric Connection into the panel drawings available from Van's. |
I'd put the transponder underneath the Garmin, above the switches :D Rosie
Hi John,
Looks like a nice clean layout. Are you planning on flying IFR? or just VFR Day/Night? Either way I would suggest a backup instrument to your EFIS such as an analog ASI and altimeter and possibly A.I. if you plan on taking it IFR. That's the biggest thing for me, even though I love all the electronics available to experimentals, it never hurts to be ready for when the screens go blank. Graham |
make sure you check the clearances for your tip up canopy
Eventually I'll take it IFR, but not before I put in a backup EFIS like a Dynon D10 or more likely, MGL Xtreme. With the EFISes each having their own backup battery, that would give me redundant flight instruments and 3 levels of power redundancy. I'd also get a second comm radio like the MGL V10.
Stupid question...
Unless I'm missing something, you have one com and one nav source (the 430)... so why the need for the very nice, but also a bit pricey audio panel?
This from a VFR only pilot who has only ever used audio panel to switch between two com's... Edit: just saw your comment about adding future equip, which makes more sense. |
What Rosie said...
Best, |
Panel drawing size
As stated above, make sure to account for the 3/4 by 3/4 aluminum angle on the upper perimeter of the panel.
Second and more important. The drawing file I obtained from Van's some years ago was the turret punch drawing PRIOR TO BENDING. I think this is still what is supplied on the website. Make sure to account for the ACTUAL height of the panel and the bend radii at the bottom flange. |
Java, How would you ID the VOR without the audio panel. I guess you could wire it in but the audio panel makes it a snap, also adding a switchable panel after the fact is quite a bit of work when you want the second radio. I did this last year and I was quite a feat for me.
Regards |
| All times are GMT -6. The time now is 01:50 PM. |
