VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   Superior switched Ignition/Starter system (https://vansairforce.net/community/showthread.php?t=6710)
BruceMe 03-29-2006 06:02 AM
A differend [better?] switched Ignition/Starter system
I've been thinking a long while (maybe too long) about how I wanted my ignitioin switch to work. After a lot of review, I think I may have taken a bit from everywhere to come up with a system that is superior. It's a hybrid of the old bat-switches with turn-key simplicity.
It uses two DPDT switches both are on - off - mom. They are $9 each from Spruce No. 11-00768.
Configured as:
--- Start ---
--- L HOT R ---
--- OFF ---
The down position for either left/right grounds that mag. Middle possition is ungrounded (hot) for either mag. Pulling both left and right together to the momentary up position grounds the right mag and simultaniously energizes the starting circuit. The starting circuit is in series so BOTH the left & right switches must be in the up position to energize the starter.
I also built a switch gaurd from two 1" pieces of 3/4" AL angle. It's dirt simple: To start, turn the master on and pull the switches up. You dont need to remember which mag has the impulse/retard or how that work. Why do I think this is better than a key switch?
1 - It lasts longer. Keys ware out; switches not nearly as much.
2 - I loose stuff (a lot), especially keys!
3 - It's safer, you have to pull two switches together to engage the starter. It would be hard to engage the starter by accident while doing a mag check.
4 - It's simpler (more basic). Installation has a couple more wires than a key system.
5 - It's cheaper ($18 vs. $52)
If you want a schematic or pictures of my installation, let me know. I just finished installing it and testing it. It works pretty well. I hope this generates some interest.
-Bruce
Davepar 03-29-2006 11:43 AM
That is a cool idea. When I saw "Superior" in the title I thought it was somehow tied to their engine.
What I need is a system this simple for the Emag/Pmag. Since they need a power switch for each, I think I'm stuck needing either 4 bat switches or 2 bat switches plus the key switch. :(
BruceMe 03-29-2006 02:39 PM
You need "ON" in the middle... It's a bit pricier. But you can find On-On-Mom switches and use the same exact system.
-Bruce
Mike S 03-29-2006 04:42 PM
Be sure you dont hook things up so as the 12v from the starting position can get into the mag--------------they dont like things like that.
And you dont need a center on as Bruce says----------
Mike
BruceMe 03-29-2006 05:57 PM
Mike
! MUST ! be DPDT - Dual Pole - Dual Throw... That means internally there are two seperate switches that pull together. This keeps the 12v source away from the magneto current.
Somebody asked, so I drew up the diagram. It's based on a diagram for a show-of-sparks system I found on Bob Nuckoll's aeroelectric.com site. I did modify it (to wire the momentary-up in series and remove the shower of sparks aspects).
-Bruce
Mike S 03-30-2006 02:14 PM
Bruce, you quote me like there is something I said that you dont agree with, but I cant figure out what it is.
You are correct that the switchs MUST be Double Pole, although I am not sure if "Double throw" would be a correct designation for a three position switch, (I.E. 1, off 2, on 3, start) Perhaps that is known as a triple throw.
In your first post, you said this circut would require a switch configured as "on, on, mom"-------that is what I disagreeded with, and your own posting of the diagram DOSENT use an "on" position in the center.
The panel is labeled as "on" when the switch is centered, but in fact the switch is electricaly "Open", or off.
Also, the way you have it drawn, the right mag is grounded when in the start position,-------and the vertical line you show connecting the movable contacts should be a dash line, as it is now, you are using the same line as your wire designations, and someone could misinterpet that as refering to an electrical connection between poles 2 and 5, not the mechanical connection I think you ment to show.
I wish I knew how to do drawings like you did, would make things clearer than words do.
Mike
Davepar 03-30-2006 02:28 PM
Actually, Bruce's initial post says he used on-off-momentary switches. The on-on-momentary was for the Emag/Pmag that I was asking about. Sorry to confuse the topic.
Labeling the middle position "on" makes sense to me. The mag is ungrounded and thus producing a spark. It follows the same logic as a key switch which is off-R-L-both-start.
mdredmond 03-30-2006 03:24 PM
Each position in which a connection is made is a "throw" for naming purposes. "Off" doesn't count as a throw, so they're DPDT switches. You can have both 2 and 3 position double throw switches, the difference being that the 3 position switch has a 'make no connections' position.
BruceMe 03-30-2006 07:09 PM
I've thought a bit about this now. When (not if) I install my pmag...
You dont have to worry about which mag is running impusle coupler/retard. Just turn them all on. All you need are two on-off (SPST) switch and a seperate guarded push-button for the starter. eezy-peezy
-Bruce
BruceMe 03-30-2006 09:23 PM
Mike
Sorry Mike, the quote was to direct my answer... I agree completely! 12v for starter does not belong in the ignition system. I think others have stated this, but I'll re-state since you directed the inquiry at me -
The on-on-mom / pmag issue threw the thread for a loop. The on-on-mom switch is pretty much a half-baked idea for solving a basically simple problem for pmag installations. See my previous post. The solution I posted is DPDT and is for the bad-old grounded manetos only.
-Bruce
