VAF Forums
-   Fuel Injection Systems (https://vansairforce.net/community/forumdisplay.php?f=94)
-   -   My EGT's have risen 100 degrees!! (https://vansairforce.net/community/showthread.php?t=66660)
pierre smith 12-29-2010 02:57 PM
...during the last two flights. After balancing the injectors up at Airflow, everything was cozy and I happily ran 50 LOP with EGT's around 1420 or so. All of a sudden, they're reading 1560 and the numbers turn yellow on the D-120. In the past, the hottest they'd get was around 1460-1470, then start dropping going LOP.
Methinks I have a couple of bad probes since only two cylinders do this while the others are 125 deg cooler. They're three years old with 350 hours on the airplane.
What say you?
Sig600 12-29-2010 03:12 PM
Fuel flow and CHT's still consistent with what you're used to seeing? May be bad probes, however if you're seeing this immediately after balancing the injectors..... ??? One EGT probe going I could see, however two at the exact same time? I'm no math major but statistically that's a stretch.
sjarrell 12-29-2010 03:45 PM
What are your CHTs? Did they go up as well or are they normal?
AlexPeterson 12-29-2010 04:07 PM
Seems like one plug in those high egt cylinders is not firing. If one plug stops firing, it is somewhat like retarding the timing.
I know if I turn one ignition off, the egt's go way up also.
asav8tor 12-29-2010 04:54 PM
BINGO!!!!
airguy 12-29-2010 07:24 PM
Possible induction leak? Is your manifold such that you could have a leak that would only affect those two cylinders driving them leaner? Do they all still hit peak at the same fuel flows as before?
aerhed 12-29-2010 08:23 PM
Restricted injector (dirt) would make EGT go up normally, but maybe not when LOP. Fuel flow would maybe stay the same with "lost" fuel from the 2 restricted injectors going out through the other 4 cylinders. That would change CHT's & EGT's on the other 4. LOP is almost like region of reverse command. Do your temps & fuel flow indicate this?
NDrv8r 12-29-2010 08:34 PM
probes
If memory serves, I think probes generally fail lower rather than higher. Does any one else have any thoughts on that?
pierre smith 12-30-2010 05:34 AM
The mag checks good...
...during runup and so does the Lightspeed.
The CHT's on those two cylinders are also close to the others and cooler than a couple as well. The cowl's coming off today for a closer look...maybe it's whispering in my ear, huh?
AlexPeterson 12-30-2010 08:01 AM
Pierre - is it possible that the two cylinders are both on the same Lightspeed coil? If so, that coil might be flaky. Since it is a wasted spark system, each coil fires two cylinders.
