1 LSE and 1 Pmag?
Anyone running this combo? if so, Pireps appreciated
thx. |
Interesting, Haven’t thought of running that type of combo in the lab. Be interesting to monitor with a 4 channel trace scope to see what the actual variance of ignition timing between the too ignitions at different rpm’s and load (MP). What version pmag? What did you set your base ignition timing and at what rpm. We have a few different makers of early and late model ignition systems here to use. I am going to check it out.
Thomas S. |
| All times are GMT -6. The time now is 04:10 AM. |
