VAF Forums
-   Flight Testing (https://vansairforce.net/community/forumdisplay.php?f=70)
-   -   -9A initial report (https://vansairforce.net/community/showthread.php?t=64608)
Daver 11-06-2010 09:35 AM
-9A initial report
Thought I'd post some initial findings.
My plane is a -9A slow build (took just short of 4 years to get it flying).
150 HP lyc o-320E2A (used 450 SMOH).
Sterba wood prop (68x72).
My field elevation is 6550'
The plane flies trim - very nice. Won't need any adjustments or tabs. I think this, in part, is a testimony to my expertise using advanced measuring equipment like a tape measure & plumb bob:D
The take off & climb performance is very good for the setup. I've gotten 1500 - 1600 FPM at a den alt of over 8000'. Of course the plane was light.
The prop is pitched a little much but I think I'll be happy the way it is. 2250 take off RPM and just shy of 2500 in cruise. I think the cruise RPM will increase as soon as I install wheel fairings.
Best speed so far is 171 MPH TAS @ 2400 RPM. I think its going to be an honest 150 kt plane. I'm more than happy with this result.
Throttled back to about 2000 RPM, I'm getting about 135 MPH @ ~4.5 GPH.
Landing is a breeze (so easy a cave man could do it). The flaps are not as effective as a C-150's and the forward slips are less extreme. Slowing down in the pattern is not a problem. You just have to plan ahead.
I built this thing for just short of $46k. Round gauge panel with a few "goodies" like an AP, fuel computer, nice GPS, vac gyros (used), etc.
The empty weight came in at 1044 so it has good useful load.
Very few minor issues; loose alternator belt, my intercomm quit:mad:- small stuff really.
Dave
-9A flying
The paint & fiberglass is still a work in progress.
This is all preliminary so I'll post another report as soon as I learn more
9GT 11-06-2010 10:05 AM
Congratulations Dave,,,,not only on first flight but also on the cost of your plane. It is nice to see that there are other builders besides myself that need to keep progress on the build with a limited budget. It CAN be done!
rv9av8tr 11-06-2010 11:29 AM
-9A numbers
Wow, GOOD JOB!!
I gained 20 mph putting the gear fairings on!
Fixed pitch props are a compromise as far as choosing a "cruise" prop or a "climb" prop. You're top end RPM of 2500 though, that's seems rather low if your condition was WOT and 8000 ft. Is your engine red line 2600 or 2700?
Ideally, a person would like to see WOT/8000 ft to at least be within 50 rpm of the engine rated red line.
gasman 11-06-2010 01:44 PM
Dave
-9A flying
Dave, You should send a copy of this thread to Van. He would be proud of you.
All we ever hear is how someone loaded up the panel and invested $85K in their over weight aircraft and now the tax man is holding out his hand.
At that weight, you will really enjoy your aircraft..........................:)
dicel87 11-06-2010 03:20 PM
Congratulations! Can you post a picture of the panel?
Really impressed with your bottom line cost too.
Vlad 11-06-2010 03:28 PM
Dave congratulations! Do you have any tips on major items where to save? I assume you are unpainted right?
Daver 11-06-2010 04:04 PM
paint
Vlad,
its painted - sort of.
I'm the kinda guy who has trouble painting the bathroom...
I need to color sand, buff, touch up, buff some more and maybe it'll be OK.
Just more work.
My engine has a dual HP rating; 150 @ 2700 and 140 at, I think, 2450 RPM, so really what I have here, I think, is a 140 HP plane with this prop.
Ed Sterba will repitch it if I want. I'm trying to decide.
I could get more RPM and, thus, more HP but I might loose some economy.
The key to building these things for less $$$ is deciding what you can do without and what kind of plane you really want..
If you want a new engine, CS prop, whiz-bang glass panel then it'll cost more.
I'm sure my plane won't win any awards but I'm happy.
I'd post a picture but I don't know how:o
I'll try to figure it out.
Thanks all for the kind words. Building and flying an airplane is an incredible journey no matter how you build it.
Dave
-9A flying
(about 18+ hrs into phase I)
videobobk 11-06-2010 05:05 PM
We know how you feel! Nothing beats flying YOUR plane. You beat me by 10 pounds and about $4k, and I thought I had done pretty well. Enjoy!
Bob Kelly
Kevin Horton 11-06-2010 05:29 PM
The rpm will come up quite a bit due to the speed increase once you put the wheel pants on. Hold off on making any decisions about prop pitch until you have the pants on.
bhassel 11-06-2010 07:03 PM
Congrats!
Dave if you ever make it up to Santa Fe PLEASE give me a call (231-4598)!
I'd love to see your 9A. Your price point is what I'm shooting for so its more than encouraging to learn of it being done. I'd love to hear how you did it!
Its great to have another flying 9A in the LOE!
Bob
