oil & fuel pressure senders
Stupid question but I want to double check...
regarding the pressure senders, OIL is 0 - 150 psi (10 bar) and FUEL is 0 - 80 psi (5 bar), correct? This is for the GRT EIS but I'm sure it's all the same. Thanks, Scott |
You have an injected engine... and Yes. I do to and those are my sensors (from GRT).
-Bruce |
| All times are GMT -6. The time now is 09:59 PM. |
