Kuntzelman Streamlined Strobe
I want a streamlined strobe to put on the tip of the VS. I have never seen a Kuntzelman Streamlined Strobe for real and am wondering if anyone else has bought one.
Is it bright? Does it look OK? (I worry it looks more appropriate for a microlight than a red blooded RV4) Would you buy it again? Any other suggestions? Thanks for your help, Steve #4478 |
-mike |
I picked one up thinking I would mount it on the belly, but I probably won't use it. The construction seems more appropriate for an ultralight than a 200mph RV.
mcb |
I use it.
I have one in the top of my VS. Doesn't affect my flying at night. Its light but simple and works well on an RV.
Got a photo?
other suggestion
Is that the Whela?
Mark - Yes a strobe. Is that the Whelan piggy back unit? If so I guess you just made up a base and cut most of the metal away? Thanks, Steve. |
| All times are GMT -6. The time now is 07:17 PM. |
