DAR Inspection - what to expect?
I have read that differenct DARs take different approaches to their inspections. I will be inspected in two weeks and would like to hear about your DAR experience and maybe some "common errors" or any changes/fixes that your DAR required prior to 1st flight. thanks, jack RV9A
I had the FAA do my inspection. It's free if you can get them to do it. Anyway, here's what I did:
Have all your paperwork ready Have an inspection check list ready Have all your builder logs, engine log, prop log, POH, A folder with all your manuals and certs for your equipment installed. Any inspection sheets from your Tech Counsellor. Display these near the plane. Have your flight testing plan made out and available. Have all the removable inspection covers off, cowl off, seats out, carpet out, covers off, basically everything off and open like an annual inspection. Neatly display all the items removed. Have the plane and surrounding area as neat and tidy as possible. Be proffesional, accommodating, helpful, but don't volunteer any info not asked for. Have coffee and cringle or danish. You should have gotten an amateur built package from the FAA. This will be helpful in getting everything ready. All these things help show the inspector the detail and depth of thought that went into your building process and test flying plans. The more organized and professional you look, the less likely you will be scrutinized and nitpic'd unnecessarily by the inspector. Hope this helps, Roberta Hegy, Been there, twice!! |
DAR checklist (VERY long)
I have attached a checklist of items needed to issue a Special Airworthiness Certificate to an Amateur Built experimental aircraft. Please make sure that fuel grade and QUANTITY at the fuel tanks, Left, Right, Off or On / Off fuel selector labels, on / off on electrical switches, and a few other required labels that I am finding are getting missed by builders.
A sample Program Letter can be found in AC 20-27F APPENDIX 13. The application for airworthiness and the Eligibility statement can be downloaded. The Eligibility statement (FAA Form 8130.12) is required to be notarized. Here are links to the forms that will need completed. Application for Airworthiness Certificate FAA Form 8130-6 http://www.faa.gov/certification/aircraft/8130-6.pdf http://www.faa.gov/certification/aircraft/8130-6.doc Eligibility Statement FAA Form 8130-12 http://forms.faa.gov/forms/faa8130-12.pdf http://www.faa.gov/certification/aircraft/8130-12.doc A good FAA Link to info on Amateur Built aircraft can be found at: http://www.faa.gov/certification/air...ur/default.htm AC20-27F, Certification and Operation of Amateur-Built Aircraft, This AC provides information and guidance in the building, certification and operation of amateur-built aircraft. http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/1ab39b4ed563b08985256a35006d56af/0ca2845e2aafffbb86256dbf00640cb2/$FILE/AC20-27F.pdf AC90-89A, Amateur-Built Aircraft & Ultralight Flight Testing Handbook, This AC sets forth suggestions and safety related recommendations to assist amateur and ultralight builders in developing individualized aircraft flight test plans. http://www.faa.gov/certification/air...r/ac90-89a.pdf There is also a lot of good information on licensing your homebuilt in the EAA Members Only section under Homebuilders. http://members.eaa.org/home/homebuilders/ They have a section on registering http://members.eaa.org/home/homebuil...ing/index.html and Testing http://members.eaa.org/home/homebuil...ing/index.html your homebuilt aircraft. Here is the Checklist to get an airworthiness certificate for your Amateur Built Aircraft: At the time of application for your Airworthiness Certification ? (a) The aircraft should be complete in every respect, and? (b) The Applicant must submit all required documentation. The aircraft must be in a condition for safe operation for the issuance of an Airworthiness Certificate. The following must have been done. [ ] Construction log for the project, photos taken during construction, and log entries describing inspections must be available. (FSDO will also want to see this to get your Repairman Certificate) [ ] Instrument markings and placards required by 91.9 are completed. [ ] Labels on fuel grade and QUANTITY at the fuel tanks, fuel selector labels, on / off electrical switches. [ ] The marking requirements of FAR Part 45 have been complied with, including permanent attached of a fireproof aircraft Identification (date) plate, permanent application of appropriate Registration marks, and the word EXPERIMENTAL near each entrance. [See FAR 45.22 (b)(1) for exemptions. Be prepared to SHOW for allowed deviation with copy of documentation.] [ ] Passenger Warning placard displayed in the cockpit in full view of all occupants (not required for single-place aircraft). ?PASSENGER WARNING ? THIS AIRCRAFT IS AMATEUR BUILT AND DOES NOT COMPLY WITH THE FEDERAL SAFETY REGULATIONS FOR STANDARD AIRCRAFT? [ ] TSO-C91A ELT installed 91.207 (except single seat) [ ] Pitot / Static Transponder test completed (91.413) [ ] Aircraft logbook, Engine logbook, and propeller logbook are available. (3 separate logbooks recommended but not required) [ ] A condition inspection in accordance with the scope and details of Appendix D of FAR 43 has been completed by the owner / builder and an entry made in the aircraft log recording the inspection with the following or similarly worded statement. ?I certify this aircraft has had a condition inspection in accordance with the scope and details of Appendix D of FAR 43 and has been found in a condition for safe operation.? The entry will include the date, the aircraft total time in service, and the name, signature, and certificate type and number of the person performing the inspection. This condition inspection does not need to be done by an A&P. The Owner / Builder can do this inspection. [ ] If a 25 hour Phase I test period is desired, a certificated engine and prop combination must be used. The owner / builder must show and the FAA must find that the engine and prop meet their Type Certificate and all ADs are complied with. (Please include a copy of the compliance list to show compliance with Type Certificate.) Required documentation: [ ] Original Application for Airworthiness Certificate FAA Form 8130-6, completed in sections I, II, and III. (Sign in blue ink) [ ] Original Eligibility Statement FAA Form 8130-12 completed in sections I, II, and III and notarized in section IV. (Sign in blue ink) [ ] Copy of a three-view drawing or photographs of the aircraft as required by FAR section 21.193. [ ] Copy of the Weight and Balance to include most forward, most aft, gross weight CG and first flight calculations. [ ] Copy of Registration AC Form 8050-3. [ ] Copy of flight test program to show compliance with 91.319(b). (Use AC90-89A as a guide) [ ] Program Letter Will make one more post with a check list that one DAR uses on RVs. This is TOO long to post with it pasted in here. :eek: Hope this helps. Gary |
DAR Checklist used by one DAR on RVs
Now a sample DAR inspection Checklist used by one DAR on RVs:
Tail Number: _______________ Hobbs Reading: Tach Reading: Confirm all paperwork is complete, and a Builder's Log or similar type record of construction is available for review. Registration: AC Form 8050-3. Application for Airworthiness Certificate, 8130-6. Signed. Eligibility Statement Amateur-Built Aircraft, 8130-12. (Notarized) Aircraft Weight and Balance Information. Check Logbook entry: ?I certify that this aircraft has been inspected on [insert date] in accordance with the scope and detail of appendix D to part 43, and was found to be in a condition for safe operation.? Airframe logbook S/N, N number, Make match Engine Logbook S/N, Match, Model match Propeller Logbook S/N, Match, Model match (3 separate logs recommended) PHOTO 2" EXPERIMENTAL placard PHOTO Experimental Passenger warning PHOTO Data Plate PHOTO N number 3" for < 180 KCAS cruise else 12" PHOTO Airplane Left Put flaps down before starting Left Wing. Wing: Left wing exterior fuel cap for security Fuel type / quanity Left Wing tip Left wing aileron bellcrank & attachments Left wing interior Left aileron balance weight Left aileron push-pull tube attachment Left aileron inboard attachment Left aileron outboard attachment Left Flap Left Flap to Wing attachment Left Flap to actuator Left wing rear spar to fuselage attach hardware. Left wing fuel tank spar to fuselage attach hardware. Left wing fuselage to wing electrical plug Left wing to fuselage fuel line Left wing to fuselage vent line Left wing to fuselage pitot / static lines Right Put Flaps down before starting Right Wing. Wing: Right wing exterior fuel cap for security Fuel type / quanity Right Wing tip Right wing aileron bellcrank & attachments Right wing interior Right aileron balance weight Right aileron push-pull tube attachment Right aileron inboard attachment Right aileron outboard attachment Right Flap Right Flap to Wing attachment Right Flap to actuator Right wing rear spar to fuselage attach hardware. Right wing fuel tank spar to fuselage attach hardware. Right wing fuselage to wing electrical plug Right wing to fuselage fuel line Right wing to fuselage vent line Right wing to fuselage pitot / static lines Fuselage: Control sticks and mechanism Left aileron push pull tube Right aileron push pull tube aileron trim system elevator trim system elevator control push - pull tube fuel valve for operation / security fuel placard fuel lines fuel lines for chafing / leaks / security / condition fuel tank vent lines primer lines brake lines flap mechanism corrosion in tailcone area inspect bulkheads and stringers for popped rivets and cracked skin inspect security of internal lines inspect security of internal wires / cables inspect canopy for cracks and fit inspect canopy latching mechanism inspect firewall for distortion and cracks inspect rudder pedals and brake operation inspect behind panel for loose wires and chafing lines Check flap control operation check rudder cables inspect cockpit instruments for markings Compass Compass Card Experimental Passenger warning inspect instrument lines Altimeter / Encoder / Transponder ( 91.411 and 91.413 (a) or (b) ) inspect cockpit fresh air and heater inspect seats, safety belts ELT Cockpit Interior Lights Illuminate Cockpit Nav Lights Illuminate Cockpit Strobe lights Illuminate Cockpit Landing Lights Illuminate Cockpit Check flap control operation Cockpit Boost pump / pressure test gascolator Cockpit Cycle engine controls Cockpit Flight control operation Cockpit Elevator Trim Cockpit Aileron Trim Main Landing Gear: inspect for nose gear attachment at engine mount inspect engine mount to fuselage check nose gear attachment check nose wheel assembly check nose tire for serviceability inspect for 5606 leaks check left tire for serviceability check left brake lining check left disk for cracks, wear, deformity check right tire for serviceability check right brake lining check right disk for cracks, wear, deformity Empennage: inspect horizontal attachment inspect vertical attachment inspect left elevator attachment inspect left elevator balance weight inspect left elevator inspect left elevator trim tab inspect right elevator attachment inspect right elevator balance weight inspect right elevator inspect elevator push - pull tube rod ends inspect tail spring to fuselage inspect rudder cables inspect control stops inspect tailwheel to tail spring inspect tail wheel chains / springs inspect tailwheel Engine: inspect cowl inspect cowl fasteners inspect engine mount inspect firewall inspect baffles inspect exhaust system & hanger Check DATA plate inspect carb / fuel injection system inspect induction system and air filter fuel lines for chafing / leaks / security / condition inspect engine control cables inspect engine systems inspect alternator belt tension perform compression check (Pull prop through for each cyl) inspect ignition harness safety gascolator Propeller: HARTZELL PROPELLER 100 HOUR INSPECTION Remove Spinner. Inspect blades for nicks and cracks. Remove all nicks, gouges, etc. Inspect hub parts for cracks and wear. Check all visible parts for wear and safety. CAUTION: Check for oil and grease leaks. REMOVE THE LUBRICATION FITTINGS ON ONE HALF OF THE HUB UNIT BEFORE ADDING GREASE THROUGH THE LUBRICATION FITTINGS ON THE OTHER HALF OF THE HUB. Logs: Make entry in Log. This airplane (list model, s/n) _____________________, registration number, N_____________ was inspected on ___/___/___. It was found eligible for the certificate requested. Entry was made in the airplane records and the appropriate limitations were issued. _________________________________________________ (Signature, FAA/DAR) 8130-6 VII J. Airworthiness Certificate issued in accordance with 21.191 (g) Notes and comments: 3 logbooks (airframe, engine, prop) are not required but ONE logbook is. I recommmend 3 in case you ever swap engines or props. FAR 91 requires that Transponder and encoder be tested. Altimeter / Encoder / Transponder ( 91.411 and 91.413 (a) or (b) ) There is really no place in the regulations that require that this be done for the initial airworthiness inspection. FAR 91 requires that it be done to fly any aircraft that has the equipment every 24 calendar months. The notes about lubing the Hartzell prop is for reference. ELT is required in 2 seat aircraft. Items that are not on the aircraft or not applicable are not checked off or are crossed off. Items can be written in if something different is seen. Most of the info from the checklist is transfered to FAA Form 8100-1 for the OFFICAL FAA Record of the inspection after the DAR returns home. I above checklist was created in EXCEL and is available in PDF format. This is what it looks like after 11 AB DAR inspections over the past 10 months. Gary |
may depend on you and the acft
My inspection took 1 hour and 10 minutes, including paperwork. Same inspector has taken over half day on other RV's. If you have any doubts about passing inspection, due to "possibly substandard", or just plain ugly work, it will most likely take longer, as the inspector will have more serious doubts as well. By all means, have as many other builders check your plane first, and you can most if not all the gigs taken care of before the REAL inspector gets there! If you have the safety wire wound incorrectly, for instance, he will be looking much more closely at everything else. I was gigged for no weight limit placard on the baggage compartment.
Ask around your area about DAR's, I got a HUGE test area, as opposed to a -4 from Ohio, or Iowa or somewhere, where he basically had to do steep turns for 40 hours to stay in the test area. You would think it would be obvious that an RV needs more space to really test the acft than, say, a Kitfox. Jeff |
DAR inspection
What typically needs to be off for the DAR inspection?
Floors? Cowls? Wing root fairings? Empennage fairings? Baggage compartment? |
When the FAA does the inspection, all they require is for the cowlings, fairings, and inspection plates to be removed. I would not disassemble the interior and remove any floor panels, seats, etc.
I've been through this twice before and that's all I did. Now, I've heard that some of the DARs go way beyond that. Personally, I'd check with your closest GADO and see if they will do it before paying a DAR. |
Well I had my official DAR inspection today.....drum role please........
I received my Special Airworthiness Certificate (it's a pink slip). 25 hrs. and 60 NM test area. pretty cool, huh. I had 3 minor squawks which were: 1. replace clevis on manual trim (I dropped it and then broke it when I stepped on it a few days ago. I confessed before he saw it clecoed to the attachment hole). 2. Replace two nuts or use thin washer on affected gear mount bolts. Bolt did not extend far enough through the nut. I knew that one also about a year ago, but forgot to replace them. 3. Install cotter pins on all rudder bolts. I knew that one also. I waited untill last night to install the cotter pins only to find out that I didn't have the correct size. I pointed this one out before he found them missing so he didn't think I was totally clueless. By the way my DAR had very good comments about Vans kits, drawings, instructions, etc. I got the impression that he wanted to build one himself. He runs the FCCJ aviation mechanics program in Jacksonville, FL. I'm not sure if this info is really boring to all of you out there, but it was a BIG DAY for me and maybe you will remember to double, triple check your nuts and bolts and also make sure you have the right cotter pins before the inspector shows up. Thanks for all the responses to my original DAR question. They were all helpful. N489JE only days from flying. Those @#*&*% cotter pins are going to cause me to look at a flyable airplane for about a week. jack #90508 |
Don't you have an airport nearby with a repair shop that you could buy, beg, borrow, or steal them from (cotters). Congrats on the "PINK SLIP".
Roberta |
Inspection
Thanks for the suggestion Roberta. I will check with the maintenance shop on field and they will probably have what I need. But, I failed to mention that I am traveling for work this week and the shop is closed on the weekend. I was hopeful that I could fly today or Sunday. So, i'm still pretty well grounded for the week. By the way, your suggestions were used and helpful.
I also made 8X11 signs that said FAA Paperwork, Construction log, Log books, WT. and BAL, etc. and laid out the material so the inspector didn't have to look around for all of it. I think you suggested being organized. It helped and he commented on how helpful it was to have things where they could be easily found. thanks again, Jack #90508. |
| All times are GMT -6. The time now is 12:18 AM. |
