VAF Forums
-   Interiors (https://vansairforce.net/community/forumdisplay.php?f=89)
-   -   Firewall insulation (https://vansairforce.net/community/showthread.php?t=63633)
Karl.Kruger 10-12-2010 10:55 AM
Firewall insulation
One of my RV friends suggested that before I get the firewall totally installed and while I still have access, to go ahead and put sound-deadening material on, his suggestion was B-quiet and it looks like the stuff.
http://www.b-quiet.com/ultimate.html
Mike S 10-12-2010 11:06 AM
Welcome to VAF!!!!
Karl, welcome to the good ship VAF.:D
There is a lot of information on firewall insulation on the forum already, one of the members has done a lot of research and testing on various materials.
Search for "firewall insulation" using the search function, pretty much anything by Dan H will be good info for you to look at.
Good luck, and again, welcome.
hydroguy2 10-12-2010 12:50 PM
Karl, give me a call. I got a source for a enough Firewall insulation(FAA approved) for 5 planes. Might even get it delivered for free, as I have to bring the roll back to Helena one of these days.
Brian
980-1193cell
DanH 10-12-2010 02:00 PM
Brian, which FAA standard does it meet?
JonJay 10-12-2010 02:31 PM
Search the threads....
DanH did a bunch of research and testing . Before I would venture into what sounds like a very simple process, I would review his hard work.
hydroguy2 10-12-2010 08:00 PM
Dan, below is info I got
Flammability Requirements
All materials meet FAR 25:853 (a), Appendix F, Part 1 (a) (1) (ii) for flammability. Certificate provided with each kit or bulk order.
I don't know if this passes your tests, but for me it's good enough.
BSwayze 10-12-2010 08:20 PM
Brian,
Did you put your firewall insulation on the forward side of the firewall, or the aft side?
I'm potentially interested in some of your extra material, too, before you take it back.
hydroguy2 10-12-2010 08:41 PM
aft of the Stainless.
I don't think it would work well in the engine compartment.
It's not my material, a guy redoing his cub bought to much and is selling it to me. I'll probably end up paying him for what I use at the same rate he bought it for. I'll save shipping and waste $$'s
DanH 10-12-2010 09:55 PM
That's what I thought. You're offering airliner cabin wall insulation, not firewall insulation. It is fine stuff for insulating wall panels well aft of the firewall, but totally inappropriate for contact with the firewall itself.
hydroguy2 10-12-2010 10:32 PM
All I'm going by is the advertisement which says Firewall certified and the stated info that some certified planes are using it in the same location.
We all have levels of risk we are willing to accept. If my firewall gets hot enough to cause this mat to be a problem I most likely already have a huge issues to deal with. My aluminum heatbox, pass thru's, rubber & plastic grommets and wiring will already be trying to kill me. YMMV
It's not my material to sell anyway, so never mind Karl....you can still call me if you want to talk RV's or something.
