VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Power Grids - Lancair style (https://vansairforce.net/community/showthread.php?t=6362)
aadamson 03-14-2006 06:03 PM
In case anyone is curious, here are some pictures of the power grids that I got for my Legacy. A freind who is building a -7 was vary curious about these, so I took the pictures.
They aren't cheap, but man are they nice. This is a dual alt/batt setup and the only grid that I didn't take a picture of is the single contactor version with the starter contactor.
Enjoy...
Rest of pictures here...
http://www.highrf.com/gallery/Power-Grids
sprucemoose 03-14-2006 09:21 PM
I'm curious what they get for one of these babies? Looks like it'd save you a bunch of wiring and thinking about wiring.
Davepar 03-15-2006 10:27 AM
That is slick. Precision Airmotive makes a similar all-in-one box that also includes a plug for ground power.
aadamson 03-15-2006 10:37 AM
That would be LAMAR
Perhaps Precision Airmotive and LAMAR are the same thing, but the MC-10 is what you are talking about. Don't think it will handle dual busses tho, it's just starter, master, avionics contactors.
As for cost, the Lancair ones are around $600 - $1000.
If I remember right, the MC-10 is also at the $600 mark. The Lancair ones, just make it soo easy to handle all the busses, contactors, switching, regulators, etc.
Here is the inside of one of the MC-10's from my Cessna 182.
buck 03-15-2006 04:18 PM
Lancair pwr grid
That looks like the center grid, the aft and forward grids are just as high a quality and while spendy make for a neat installation. They just don't supply a system schematic to go by.
sprucemoose 03-15-2006 04:33 PM
Originally Posted by aadamson
As for cost, the Lancair ones are around $600- $1000.
Wow. I see about a hundred bucks in parts in there. You still think you can finish for $150K? ;)
aadamson 03-15-2006 05:25 PM
Not only that.
Oh, yes, will make that easy. That number not only includes the power grids, it also includes, 4 wks of build assist, a fast build firewall option with all the parts, cables, hoses, tubing, fuel fittings, etc - all pre-assembled and mounted on the firewall. I also included a fast build electrical option that includes these 3 grids, the battery boxes, etc. And a fast build engine option that includes all the engine mounts/dampners, bushings, cable mounts, precut baffling, fuel selector, gascolator, fuel pump, precut baffle seals, ram air, etc.
I'm also doing a fast built panel option, where they do the metalwork, powdercoat, paint, etc and I'll stuff the dials and gizmos and wire it.
Yep, all that and I should be less than 150K even with the panel. BTW, here is the latest panel
aadamson 03-15-2006 05:27 PM
Sure they do
Of course they provide a system schematic.... of the power system. At least I got one. As for the rest of it, if you buy their fastbuilt harness and full panel, you get all the rest including bound documentation, and schematics.
I'm doing most of that work myself, so I just opted for some options that I didn't have the tools for, nor the inclination to build. The power grids fall in that category.
w1curtis 03-15-2006 05:27 PM
2 ANL fuses + 1 ACG fuse + 2 Master relays + 3 diodes + Copper stock = $600-$1000 --Wow indeed!
Think they have any of the $200 hammers left?
Somebody has found a new way to print money. At least the MC-10 has a voltage regulator built in. Maybe there are some electronics on the other side that we are not seeing?
aadamson 03-15-2006 05:33 PM
Sorry
Yes, there are 3 grids, primary with avoinics buss, essential, and starter. Plus the other regulators. I got it all in a fastbuild electrical kit, I've never stopped to make a full and complete inventory.
