VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   Installing a Filterred Airbox on a throttle-bodies (https://vansairforce.net/community/showthread.php?t=6335)
BruceMe 03-13-2006 02:48 PM
I tried to dry-fit my FAB on a Bendix throttlebody and the mixture arm interfeers something crazy. Anyone have pictures of the solution(s)?
-Bruce
fodrv7 03-13-2006 03:56 PM
Horizontal or Vertical
Bruce,
Is it a Horizontal or Vertical induction.
Mine is Horizontal. I had no interference problems with the mixture arm.Can send you pics.
Pete.
BruceMe 03-14-2006 04:40 AM
Bendix throttle body
Oh yah... you probably need to know this stuff...
This is an O-320-B2C converted to fuel injection. I have a vertical induction Bendix throttle body. I put the mixture on the left, throttle on the right. The throttle is up high, the mixture has an arm that's tucked way in tight and just barely makes full throw without interfering with the TB itself.
-Bruce
