VAF Forums
-   -   Emergency Exit Glass Hammers (https://vansairforce.net/community/showthread.php?t=62604)
ghatch 09-15-2010 12:27 PM
Does anyone know if the car-type glass break hammers work on our plexiglass canopy. Hammers such as LifeHammer seem to work fine on auto glass but plexi is different.
Thanks for you input,
Gerry Hatch
Sam Buchanan 09-15-2010 12:34 PM
Gerry Hatch
Gerry,
See this thread for extensive discussion of your question:
http://www.vansairforce.com/communit...reaking+canopy
FresnoR 09-15-2010 12:45 PM
Try This Out
I've never seen one in real life, take the guard off and it may work to create a line deep enough to break yourself out:
http://www.amazon.com/Skil-2352-01-3...4575965&sr=8-1
apkp777 09-15-2010 12:55 PM
I have used a tool like this many times (cutting aircraft carpet on Jets). It would never work on a canopy.
apkp777 09-15-2010 12:58 PM
I have a hammer like this one: http://www.denlorstools.com/home/dt1...ng_hammer.html
in my plane. You can get it at Auto (and aircraft) Zone for about 8 bucks.
I don't know if it'll work, but I think so.
FresnoR 09-15-2010 12:59 PM
I meant it more in an emergency to score the plexi, much like when you score a line to cut glass. I posted that before I read the other threads, it looks like the hammers and axes discussed would work better anyway. Heck, even a compact pistol, but that might create other problems.
apkp777 09-15-2010 01:10 PM
LOL. I vote for a sawed off shotgun! No, I think it would take too long for that cutting tool to do what you wanted. What ever you use needs to be quick as you will be upside down and possibly in water or fire.
Wayne Gillispie 09-15-2010 01:21 PM
We had a crash axe on the UH-60A
Very similiar to a hatchet. I am sure it would have worked very well on plexiglass.
647jc 09-15-2010 02:08 PM
I carry a Coleman camping hatchet with a sawed off fiberglass handle, not as exciting as a sawed off shotgun but much cheaper.
ghatch 09-15-2010 03:32 PM
Thanks guys for you responses and advice. I'm leaning toward the S & W 911 as being light, having assisted opening and spring loaded punch all to make life easier if space is limited and only one hand is available.
Gerry
