VAF Forums
-   RV-4 (https://vansairforce.net/community/forumdisplay.php?f=9)
-   -   RV-4 RG...Hall's Airshow (https://vansairforce.net/community/showthread.php?t=62498)
jmbrwn 09-12-2010 07:20 PM
Attended the Hall's Tn (M31) Airshow today and noticed a RV4 RG. Here are some pics for those interested.
Here's rest of pics from Hall's Airshow
http://share.shutterfly.com/share/re...9AasnDFy5bqIH4
KirkGrovesRV8 09-12-2010 09:32 PM
Really Really cool:D
Sig600 09-12-2010 10:34 PM
Wow, that's a lot of work, engineering and cash!!! Would love to see some inflight shots with the gear up.
longranger 09-13-2010 09:15 AM
Definitely an A+ on the cool factor, but it would be interesting to see some un-biased testing to see whether/how much the decreased drag makes up for increased weight...
JDRhodes 09-13-2010 09:22 AM
Where do you put the gas? :confused:
L'Avion 09-13-2010 09:50 AM
N8DU is owned by PR "Bob" Gallagher, based at M01, Dewitt-Spain Downtown Airport here in Memphis.
Here's an up close shot:
Barney, in Memphis
RV-4 flying
RV-3 flying
Chino Tom 09-13-2010 01:21 PM
Looks like the fuel tanks are outboard of the landing gear in the leading
edge. Note the sump drain in the pictures.
N8RV 09-13-2010 02:46 PM
[img=http://img97.imageshack.us/img97/4559/bob017x5.th.jpg]
Barney, in Memphis
RV-4 flying
RV-3 flying
All that RV needs now is a belly scoop, kinda like "Beautiful Doll" (in Danny's dreams!)...
Stitch462 09-15-2010 11:50 AM
A belly scoop and a sliding canopy to complete the whole P-51 effect! :D
Pave Tim 09-16-2010 12:50 PM
Where are the guns?
rpellicciotti 09-24-2010 06:33 PM
Ok, here ya go:
http://www.youtube.com/watch?v=d506a6Id5CY
Enjoy!
flyeyes 09-25-2010 08:33 AM
I have a single datapoint.
My rv-8 has the same engine and prop as this airplane, except that I have electronic ignition to his bendix mags. He has high-compression pistons and a cold air intake, while these parts are stock on my airplane. We both have 4-into-1 exhausts, although mine is prettier and I suspect flows better.
I have flown a lot of formation with this airplane (he hangars next to me) and while we are evenly matched in the climb, I can easily pull away from him in cruise or downhill. At WOT down low I have about 5 knots on him, with similar weights. (his empty weight iirc is about 80# more than mine)
Kiwi 09-25-2010 11:09 PM
Any other RVs?
A number of retractable gear conversions have been done on RV4s. Does anyone know if any have been done on RV6s, or any other RVs?
Andrew.
Kevin Horton 09-26-2010 05:10 AM
Bryan Carr, who already built two RV-4s with retractable landing gear, is currently building an RG Rocket. This will be the tenth RV or Rocket that he has built.
Christopher Murphy 09-26-2010 06:28 AM
RG Rocket
I would think that ,at rocket speeds and the higher power to weight ratio, the RG gear would make a bigger difference in top end performance. I could imangine a HR3 with RG.
CM
WillyEyeBall 09-26-2010 07:41 AM
RV-4 retract
Originally Posted by rpellicciotti (Post 470174)
SUPER video, and Great flying.
Thanks, and added to my favorites.
Bill McLean
RV-4 Slider
RV-4 09-26-2010 10:01 AM
Retractable RV-4
It sure looks good but was the spar reinforced to take the extra load of the retraction process???
I believe it was a problem with the Rockwell Commander spar following Rockwell's changes in the design from fix to retractable along the way resulting in cracks in the spar later on..
That is something to consider I would guess..
L'Avion 09-26-2010 12:41 PM
RG
For anyone interested in experimental RG, here's a good site:
http://www.iflyez.com/InfinityGear.shtml
"Waiter" (his site above) was a big help in solving intermittent problems with the gear on N8DU, subject RV-4RG in this thread.
http://www.ez.org/smf/index.php?PHPS...cseen#msg11955
It was some of the EZ guys who helped me decide to go with aluminum-skinned fiberglass fuel tanks to replace the ancient leakers on my RV-3. Not a leak, nor nary a problem, in nearly two years with the new tanks.
Barney, in Memphis
RV-3 flying
RV-4 flying
don.olandese 09-26-2010 12:51 PM
and the exhaust stacks?
rpellicciotti 08-22-2014 08:27 AM
RV4RG
How about some video?
http://youtu.be/d506a6Id5CY?list=UUv...t4qJ5q3fgC584Q
FORANE 08-22-2014 09:23 AM
Excellent!
I have flown into Halls TN on a few occasions. If I recall correctly, it is an old AAF base. The runways were pretty rough with some significant ridges.
There is or was a guy there (Roy Smith) who did static, altimeter transponder certifications. Also there or a few miles from there in Dyersburg is the home of Boss Hoss motorcycles which are powered by the Chevy V8.
