Question for DARs regarding flight test area
How large of an area can I request to perform my Phase 1 & 2 flight testing? Is there a tactful way to request an area larger than 25nm on my Program Letter? Thanks!!
not a DAR, but I drew a trapezoidal area on a sectional and submitted that. About 50 mile radius and included a couple airports I wanted to be able to get to. I'm on the coast, so it was sort of a half circle/trap. I did stay clear of busy/dense areas and the class B. No problem.
Work with your DAR, especially if you are around populated areas or crowded airspace. It usually is not a problem. I routinely do that for my customers.
Vic |
I asked for 35nm centered on my home base and was given a 50 nm radius centered on an airport 25 nm south of my airport giving me a 75nm reach to the south. His explanation was he knew several airfields in those areas that have routine fly-ins with great pancakes... :) Great guy!
Thanks for the input . . .
I'll ask, give my justification and see what happens!
50nm was a standard around here and you didn't even have to "ask" nor "explain"
200nm
radius, excluding the Kansas City Class B airspace, was asked for and authorized by the DAR (retired FAA Inspector) I hired. I stayed close to the local airport during the first 20 hours of Phase 1 testing, then ventured to far away places in the HUGE area available to complete the 40-hour Phase 1 requirement.
Best regards, Bill RV-7 N151WP Barrett IO-390 Lee's Summit, MO |
I used the FAA and asked for a 75nm circle and got it without further explination, should have asked for more!! oh well, I'm free to roam about the country in 1.25 hrs :D :D
Got 40nm without even asking....
Test area
'ye have not because ye ask not'
I work with folks to give them what is needed for the particular aircraft. RV's need lot's of room! You can fly out off a small area very quickly. The objective is to conduct flight tests, not take a navigation quiz! |
| All times are GMT -6. The time now is 04:43 AM. |
