Wing root seal racket
I know others have experienced this and I sure am glad that I was prepared from reading about their experiences but WOW, when a gap seal comes loose it sure makes one horrific racket.
After 20 hours into phase one, my topside trailing wing root seal peeled away, at first I thought I had a failed cylinder or some other engine catastrophy from the loud banging but the engine was obviously fine. I could not see the seal flapping and slapping the wing and fuselage but I sure could hear and feel it. Is was no better at slower speeds. I was pretty close to the airport and landed in about ten minutes wondering how much damage had been done... None. Back at the hangar I used some carpet tape to better anchor the end. I am going to add some more tape to make sure that this does not happen in flight again. |
Oh man. that happened on my first flight, with no airspeed indication and an EFIS attitude indicator showing a 70 degree nose up attitude and 90 degree bank.
Man, that will get your attention! I aged a few years on that one. |
A few dabs of RTV placed inside the rubber channel will keep it in place. I suggest doing this after painting, as RTV and paint don't work well together.
greg |
| All times are GMT -6. The time now is 04:43 AM. |
