VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   Rough engine on EI (https://vansairforce.net/community/showthread.php?t=61517)
rv6aviator 08-18-2010 03:24 PM
Rough engine on EI
Gentlemen. I have an RV6, w/ Lyc 0360- Recently developed rough running which seems isolated to the EI side since - runs ok on mag side only and somewhat rough on both. All wiring and plugs have been checked. The EI is on right side and has no identifying marks anywhere on it that I can find. Is has aluminum look round housing w/ a multi pin plug near top and a small green plastic thingy ( I know ,I know) just south of centre which looks like it might be an LED light. 2 coils are mounted on top of the engine, rectangular, flat on top. Sorry don't have pics of this yet but can anyone identidy the unit and more importantly, how to dianose the rough running and how to fix. I defer to your greater knowledge.
Birkelbach 08-18-2010 03:34 PM
Does it look like this?...
http://www.myrv7.com/viewimage.php?pictureid=383
Another shot is here...
http://www.myrv7.com/viewimage.php?pictureid=473
If it does then it's a Lightspeed hall effect sensor.
Here are some manuals...
http://www.lightspeedengineering.com...s/Ignition.htm
The little green dot is in fact an LED that is used for timing. The details are in the manual.
rv6aviator 08-18-2010 04:50 PM
That is exactly what it looks like. Don't know why it would not have some id on the case but... Tks very much
RVadmirer 08-18-2010 05:04 PM
EI Issue
Check your PMs
Ron Lee 08-19-2010 02:37 PM
I had a rough running Lightspeed a few years ago and replacing several parts fixed the problem after returning to the original part. I think that removing and replacing the two DB connectors cleaned off some corrosion.
Another time a wire connection to one of the coils failed and that was easily fixed.
Do read and follow the troubleshooting guide in the links you were given.
rv6aviator 08-19-2010 03:03 PM
Cleaned the connector at the Hall effect unit, checked the coils (good), checked the plugs again (good) and moved the Hall unit as per Lightspeed Manual kindly linked to me above. The led light came on and off as suggested but the off point was about 5* arc clockwise to where the unit was set before (25*engine). Ran engine and not getting that hard occasional knock I was getting but still not real smooth on the EI. Do you set the Hall unit where the LED light first comes on or where it goes off or in between- the manual is not specific on that?
Birkelbach 08-19-2010 03:25 PM
You set it as the LED turns OFF. If you use the point where the LED comes ON you will be about 5 deg off. This was a problem with my engine when I first got it.
IIRC if you are turning the engine in the normal direction of rotation the LED should come on around 5 deg BTDC and then go off right at TDC. (For 25 deg engines)
I did do the automotive timing light test and it's a little nerve wraking having the engine running inside and being trapped between the wing and the prop, but that's how you get the definitive answer on your timing. You may have a MAP leak or something causing the timing to be off. The HAL effect sensor won't tell you that, but the timing light will.
Schmeddz 08-27-2010 04:38 AM
90 percent of the problems will either be wiring related or a vacuum leak. On the Light speed it will probably be wiring. Check your connectors and don't be afraid to open the DB connectors and check the soldered connections. You might be surprised at what the soldered joints look like. (Bad, cold connections.)
