VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   A must read for / Single Electronic Mag Users (https://vansairforce.net/community/showthread.php?t=59024)
G3i Ignition 06-11-2010 11:08 AM
G3i will in KOSH again this year in hanger ?A? booth #1148 demonstrating and releasing the new Series-SC (Single Channel) which focuses on curing the issues of the off-set ignition timing events with the ? EI and ? magneto systems. The G3i SC module reads the variable/ advance-timing signal from the existing aftermarket electronic mag. The SC tracks it, and timing it in perfect synchronization to fire the magneto at the same timing event as the electronic mag. With a multiple spark technology. Dual EI?s and keeping your existing single magneto as an added redundancy. Here a example schem.
Thomas S.
www.g3ignition.com
szicree 06-11-2010 11:47 AM
Looks cool. However, doesn't this defeat the idea of independent ignition systems?
flyboy1963 06-11-2010 11:50 AM
must have!
Thomas,
1.what the price on this unit alone? didn't see on your site.
2. what's the odds of me wiring this successfully?...or do I really need to get a mechanic/shop do it? I've wired automotive stuff, but all this ignition jargon makes my head spin.
thx
Jamie 06-11-2010 01:25 PM
Looks like if the EI goes TU the mag will still be there to fire the plugs.
szicree 06-11-2010 02:04 PM
It'll be there, but the description seems to indicate that the mag gets its marching orders from this device, which in turn gets its signal from the EI. If the EI fails, will the mag revert to standard timing? What if the device fails? Does it affect both ignitions?
G3i Ignition 06-24-2010 09:13 PM
Hi Steve,
That’s right, the magneto interface with the SC-E module and gets its marching orders from the existing EI example, Pmag, LS, etc.
(?)1. If the “mother signal EI” fails: By selecting off for that ignition system, with the G3i SC-E module still powered up. The SC-E will switch to the contact set in the mag and will fire at the fixed timing event with multiple spark discharge as our other G3i systems.
(?)2. What if the device fails? Does it affect both ignitions: By powering down the SC-E, the mag reverts back to default/normal and any EI input signal is internally disconnected by default, both systems are completely separated.
Next week there will be a short article posted here with some info on the new G3i Series – SC-E and there will be the install manual up on the G3i website to view.
Thomas S.
www.g3ignition.com
KOSH Booth#1148
az_gila 06-24-2010 09:53 PM
What happens...
Originally Posted by G3i Ignition (Post 444601)
Hi Steve,
That?s right, the magneto interface with the SC-E module and gets its marching orders from the existing EI example, Pmag, LS, etc.
(?)1. If the ?mother signal EI? fails: By selecting off for that ignition system, with the G3i SC-E module still powered up. The SC-E will switch to the contact set in the mag and will fire at the fixed timing event with multiple spark discharge as our other G3i systems.
Next week there will be a short article posted here with some info on the new G3i Series ? SC-E and there will be the install manual up on the G3i website to view.
Thomas S.
www.g3ignition.com
KOSH Booth#1148
...if the fault is in the C1 or C2 terminals or associated electronics.
A short to ground on C2 or a break in the C1 lead/connections/electronics would seem to kill both systems...
Have you left a few single point failure modes in the system?
G3i Ignition 06-25-2010 06:09 AM
Hi Gil,
The bnc terminals C1/C2 are only for the mag part. Shorting or opens will not affect the other ignition system from continuing. The SC-E module job is to read the timing event from the other EI and fire the mag in EI sync. Designed to not affect the other EI system if a failure was to take place with the G3i Ignition system, ex. Emag, LS. etc...
Thomas S.
www.g3ignition.com
az_gila 06-25-2010 07:54 AM
So you are saying...
Originally Posted by G3i Ignition (Post 444663)
Hi Gil,
Thomas S.
www.g3ignition.com
...that there are no common circuitry/wires/conectors in the "control box" that could cause either the EI or magneto to fail at the same time?
G3i Ignition 06-25-2010 09:16 AM
Gil,
When the SC-E is powerd down, all EI connection/ signals go open to the other EI and the mag goes back to normal configuration.
Thomas
