This Lycoming Service Instruction provides advice:
http://www.lycoming.textron.com/supp...dfs/SI1435.pdf I agree, the SS line is much neater, that's what I have on mine, but ensure you use steel fittings on the engine (replacing aluminium fittings with steel ones was covered by an old Lycoming SB). |
Thanks, all.
I've seen the Lycoming service instruction, have it printed and lying on my workbench, in fact. But it's quite vague about the hose installation. As for my Superior-supplied hose, it's Aeroquip, with brown integral firesleeve. Attempting to route this one is bad enough. I did some searching and found Steve Sampson's blog. He routed his over the top as I proposed in my last post: http://gikonfwf.blogspot.com/2007/12...-oil-line.html Since the hose I have is Lycoming-approved and the supplied block & governor fitting are steel, I'm not too keen on forking out for the oh-so-expensive stainless steel part. I've seen the routing of the stainless tube, as my hangar partner has one on his airplane (not an RV, but I've forgiven him). I'm leaning towards Steve's solution, which can be seen in the top photo in the link above. |
Lar, the other end is visible in the third and fourth picture here if you are still interested.
I only have about 80 hours on it but it has worked just fine for me. I would do it again that way just to keep it out of the crowded area under the engine. |
Does anyone have a part number for that clamping bar? My docs are too old or simply show a pic with no part numbers. |
It's a...
http://www.aeroinstock.com/products/...ail/index.html |
Seriously, I guess I should look into that. Biggest issue will be finding a flaring tool for the 3/8" st. steel, though there are a few well-equipped hangars around me I can turn to with a woeful look. |
The same tools you use for the 3/8 fuel lines will work just fine.
| All times are GMT -6. The time now is 03:28 PM. |
