VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   No oil pressure after removing Christen system (https://vansairforce.net/community/showthread.php?t=5828)
srv 02-16-2006 09:37 PM
Hi,
Question for a friend. He's got a IO-360 and removed his Christen Inverted oil system. Now he's got no oil pressure. Checked for a gauge problem, and it appears fine.
Any ideas for what he should check for?
Thanks.
garnt.piper 02-16-2006 10:46 PM
No oil pres
Check that the plug up where the oil screen goes has been removed to let oil in to the oil pump pickup from the sump.
