O-320 - Push Rod Shrouds and Retaining Clips
The new retaining clips that come from the shop do not fit over my old plastic push rod shrouds but rather sit on them. The shrouds are pretty thick walled. I am concerned that this is not a good set-up. Someone at my local airport said he thought there might be a Lycoming SB on it but I can't find anything. Do I need all new metal thin walled shrouds or do they make different style clips other than the LW14995 that are flat? The engine is a parallel valve O-320 D2A.
Thanks for the advice. John |
The old springs are flat...
...and rectangular with a 68517 part number.
AERO shows them, but way into the sticker shock category...:eek: http://www.aeroinstock.com/products/...ail/index.html ...and two per cylinder are called out. I presume that the new "dogbone" springs and push rod tubes are interchangeable, but would like to hear it confirmed... |
TUBES
The new tubes are 15.78 each or I can set you up with a good looking set of the new style for 5.00 each.
Jesse |
shrouds
Jesse, I was checking out your website and was going to call you about it. Do the $5 ones work with the new type spring clips? In other words are they thin walled and will the clip fit inside them rather than resting on them? How are the $15 one different from the $5 ones? Do you know if there is a SB regarding the shrouds?
Thanks John |
Lycoming Service Instruction 1277A deals with this and explains the differences in the push rod tubes and the two different retainers that are used with them.
Good Luck, Mahlon "The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk." |
TUBES
The 15.00 ones are the new tubes with the thin wall. The 5.00 one are the thin wall used tubes. I can pull you a nice set without any dents if you want the used ones.
Jesse |
Does anyone have...
...a copy of Lycoming Service Instruction 1277A that Mahlon mentions?
It's not on my PDF collection of Lycoming documents....:( |
shrouds
Jesse: Done deal. I will order them later.
Gill: I could not find it either. Lycoming don't have it on their site and I cannot find it on Google. Anyone got it please link it or email me a copy. Thanks. John |
Jesse,
I inspected my retainer springs in my ECI engine (100 hrs TT) and had one broken spring. Glad I checked! Just an FYI to all ECI engine owners. |
RETAINERS
Bret,
I am really glad you checked them. I am very suprised that ECI has not done something about that yet. It is definately a problem that they need to deal with. If anyone wants a copy of SI1277A send me a e-mail and I can scan a copy for you. Thanks, Jesse Jesse@a-e-r-o.com |
| All times are GMT -6. The time now is 12:00 PM. |
