First Flight, Test Dummy
Okay, I am starting to think about my first flight. I have a fellow CFI that has more than 1000 hours tail wheel, 10k total time and about 20 hours in an RV that would be willing to take the maiden flight. Myself, I have minimal tail wheel (<10 hrs) time but over 1000 total. (CSEL, CMEL, CFI Inst.) My ego says "I'll be the first one to fly MY plane!". My intellect says, "Hey, cheep insurance to have Kurt do the first one or two flights".
I could drop $1000 and get myself another 15-20 hours in a tail wheel, another $1000 for some transition training. Or let someone already qualified do the first few (and potentially most dangerous) hours. I have no doubt that I can fly the plane, just with a new engine that will have only minutes on the tach at the first flight, I am thinking I want a more qualified pilot at the controls. What do you think, is it absurd to give up the maiden flight? Be honest, what would you do? |
"Hello, Kurt? I need a favor..."
Ego can be expensive, and in the long run what difference does it really make who gets the first flight? It's still YOUR airplane. My $.02 |
i will fly mine...
passing on first flight is a bit like droit de seigneur!
i would forever regret passing on the first flight... although my risk may be higher, it will be mine and i will manage it to acceptable levels. |
Let him take it! It takes a ton of stress off you. I watched mine do the first flight from another plane!
Tony,
You have exhibited good judgement by asking the question. I would get transition training from one of the very experienced CFI's that are available, and then ask yourself the question again. Best regards, |
My thinking is, if I had an engine failure (not unheard of in the first few hours) my emotional attachment might blur my decision making ability. |
I should add that I experienced an engine failure on take off in a Cherokee I owned. I know how it feels to have your mind wrestle with the thought "this is the day I die". |
engine failure risk management
i share your thoughts tony... the first flight is generally limited to a quick shake down followed by a thorough inspection... i would expect the greatest engine failure risk to occur after vibrations have a chance to work their magic on something critical. can you catch this with a short static run? will a problem surface in the first hour of flight? is it more likely to occur after 5 hours, 10, or 50? (a recent 10 in ifr conditions) from documented mechanical failures over time they do tend to occur most frequently at the beginning and end of the life of the engine in a U curve over time.
how long do you differ flight to someone else? although the risk of engine failure diminishes over time it remains highest for more than the first flight. |
Talk with your Flight Advisor!
That's why we have flight advisors. Your flight advisor will help you evaluate whether or not you should do the first flight. MOST of the time, it is highly recommended that you let a more qualified individual perform that all important flight. A more experienced pilot will have the expertise to concentrate on an unexpected problem and flying the airplane will be second nature.
Look at it this way, if you let Kurt make the first flight, you will have two first flights. One for the airplane and one for you. |
My situation is a big negative to an ECI kit engine. That is, no test cell run-in. Had that been done, I would definitely be doing my first flight. |
| All times are GMT -6. The time now is 04:42 AM. |
