VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   throttle & mixture attachment for XP-IO360 (https://vansairforce.net/community/showthread.php?t=5750)
roadrunner20 02-13-2006 07:25 PM
throttle & mixture attachment for XP-IO360 ** Update **
Problem solved.
I was able to modify Van's throttle bracket to work on the XP setup.
Use rear hole, rotate to drill 2nd hole. Van's was 3/4" distance, XP needs 7/8". Edge distance ok. Change Van's 2 bends to 90 degrees.
Perfect alignment with throttle arm and Vans' fwf hole.
Dan
Anyone have pix of this setup?
I have the horz intake with the ryton sump.
I bought Van's kit which was recommened by Superior but can't see where this setup would apply.
Thanks.
