VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Cross Country In An RV-12 (https://vansairforce.net/community/showthread.php?t=57193)
JBPILOT 04-26-2010 09:11 AM
EGT's
I usually see about 1200 - 1300 degrees.
John Bender
Newbie_Doo 04-27-2010 01:15 PM
Decalin
Here is the link for Decalin: http://www.decalinchemicals.com/fueladditive.html
(I do not derive any benefit for pimping this stuff here...I just remembered the product name and that it had a good reputation among the alternative-engine crowd).
Cheers!
Peterk 04-27-2010 03:08 PM
Florida Trip
One other thing about the Florida trip that I learned from Gus (after I got there of course) was about the auto-pilot. If you put it on "track" as I had been, it tracks the heading of your destination (which changes as you get closer) but if you put it on "nav" it makes those changes for you automatically. The trip home was even better since I never had to change the settings on "nav". One reminder for the early builders, "nav" will not work unless your HSI is working on the Dynon. It won't work on the Dynon unless you have changed your Aviation to NMEC settings to "normal" on the 496...from "fast". I think Stein may have changed that on later avionic shipments, I don't know.
