VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   low voltage light (https://vansairforce.net/community/showthread.php?t=5644)
Build9A 02-09-2006 09:21 AM
low voltage light
Van's has a low voltage warning light for $73. Does anyone know of a cheaper alternative? Maybe with pictures of the installation and connections. Thanks
aadamson 02-09-2006 10:09 AM
Wow, if you haven't
The best money you'll spend anywhere is to go get the "Connection", its a book all about wiring, etc. Covers just what you need. From - www.aeroelectric.com.
Also if you look around the site, you'll probably find what you need as well without buying the book. Bob has a separate module, or it's built into the B&C voltage regulators. Schematics, etc are included in the book and on Bob's site for free.... Look for the appendix Z document.
Alan
Build9A 02-09-2006 12:27 PM
thanks
Haven't visited aeroelectric in awhile. They have a description of a cheap alternative that you make yourself out of an LED bulb. thanks.
andyrv 02-09-2006 01:17 PM
Which Regulator?
Which regulator are you using? I believe the B&C regulator that a lot of people use already has the low voltage function built in to the unit.
Andy
gmcjetpilot 02-09-2006 01:51 PM
Internal Regulated ND alternator has LOW volt light
If you are using a NipponDenso alternator with internal regulation it has a low volt / no charge light incorporated. Many don't wire it in, but I suggest it is a good thing to do. George
vlittle 02-09-2006 06:22 PM
low/high voltage warning
If it's in your budget, the Monroy ATD-300 Traffic Monitor has both over and undervoltage voice alarms.
I highly recommend these traffic monitors for their intended function, and the voltage alarms are a bonus.
Vern Little
9A 9.9hrs
hevansrv7a 02-09-2006 06:44 PM
Garmin has it
If you have a Garmin 295 or 296 and probably others, if they are running on ship's power, they will warn you when the voltage drops. I found out the hard way not to ignor that message!
h
