Tip: Use of AN fittings with Nylon tubing
I am in the process of running the various static and pitot tubes etc in nylon tubing. I was about to use Nylo-seal fittings which are big and bulky behind the instruments when it was suggested that I simply use AN-4D fittings with the 1/4" nylon tube as I would for aluminium tube.
Sounded a good tip but I found that the tubing was very prone to pulling out after flaring as the nylon reverts to its original profile when tightening the filtting. Tip..... What I found was that if I flared the tube and whilst still in the flaring tool I gently heated the whole kit and kaboodle with a heat blower (hair dryer is hot enough) then let the tube and tool cool, the flare remained beautifully after the tool was removed. Another tip...don't forget to put on the sleeve nut first! |
Fittings
The nylon fittings would have been a better choice. We have them, and no problems with fitting.. A better choice then "adapting" an AN fitting would have been brass with plastic compression ferules. They're cheap. strong for the job, compact and simple to install. Most large harware stores carry them.
T88 RV10 |
pitot fittings
The easiest method to plumb the pitot/static system is with no fittings! :eek:
Just but barbs on the instruments and hook everything together with a handfull of plastic tees and clear plastic hose. The purists hate this but it works beautifully, installs very quickly, and has been working great for years in a bunch of RVs. Sam Buchanan |
BTW-- I also like the blue silicone static tubing that comes with the Rapco vacuum pump kit. I'd have run more of that behind the panel instead of the stiffer plastic tubing, had I been aware of it. |
Sam,
What size and type of tubing is the standard for this approach? I looked at the barbed fittings that fit into the nylon tubing that comes with the kit and they are TINY! The orifice in them just looked a bit too small for my taste. I'm thinking that a bigger tubing would've been the way to go. In the end I used the Nyloseal fittings, but am not really all that happy about all those screwed together failure points. |
low tech, simple, cheap, can be quickly modified.......and doesn't leak.
from Mr. Adamson
from Mr. Zicree Quote:
Grab some fittings, got to Home Depot, stand in front of their assortment of hoses......and figure it out. :D The beauty of this system is that it is low tech, simple, cheap, can be quickly modified.......and doesn't leak. Sam Buchanan |
Leaks
Sam .. the plastic tubing pushed over barbs can leak over time when expose to high temperature (like the desert... :) ..) Ask sailplane pilots in the Mojave..
My sailplane uses these fitting everywhere and the neat trick is to push (roll?) a small O-ring over the tubing before installation. After the end of the tubing is pushed onto the barbs, the O-ring can be rolled back so it falls into the narrow portion of one of the barbs. This will apply a nice sealing pressure around the tube. Cheap and easy... gil in Tucson.... |
Sam or az_gilla have you got pictures?
I have found some tubing to be more pliable than others. The "softer" tubing seems to conform and to and grip the barbs very aggressively, so much so that it is nearly impossible to pull the tubing off the barb. A little prowling in the aviation department of various hardware stores or your local auto parts emporium will turn up tubing that is suitable for our uses. Sam Buchanan |
Use of AN fittings on nylon tubing (continued)
Thank you all for the advice on perhaps not being too quick to use AN fittings with plastic tubing..
I now have some barb fittings installed. I did however use some bulkhead AN fittings to bring the tube from the wings through the side of the cockpit area. I suppose I still feel that if one uses AN fittings with Nylon then heating the fllaring tool and nylon tubing will hold the flare after the tool is removed.. Anyway I took on board the discussion and modified my ideas.....that's what it's all about! |
| All times are GMT -6. The time now is 07:22 PM. |
